Sip trunk between callmanagers
pcromwell
Level 3
Level 3
Sip trunk between callmangers 8.5 - 10.5. calls work fine. But when we call from 10.5 side the other end is not getting calling name. it is getting the calling number. when I do a Sip trace, I see that 10.5 is not sending calling name in the invite.
When a caller from 8.5 calls su, he does get remote caller I.d
I have checked the trunk config. I have changed all the calling presentations from default to allowed and also on the route pattern
but still no joy
Hi.
Can you please send a trace of CUCM 10 during a call to an 8.5 user?
Carlo
Please rate all helpful posts "The more you help the more you learn"
many thanks for the response, we have jsut managed to sort it out. In the User device profile line settings, the ASCII display setting was blank. we populated with user name and it worked.
bit strange that
