sip trunk between cme 7.0 and ccm 4.1
giovanni.cock
hi, i am trying to make a sip trunk between a cme 7.0 and ccm 4.1, the ccm 4.1 already has a sip trunk working to an OCS, so i created a new one, but i had to change the ccm's incoming port to 5061, to create it.....!!so i want to know, how can i configure the cme to point the sip trunk (dial-peer sip), to the ccm's 5061 port.
This command will also change the port used to send SIP traffic.
Hope this helps.
Brandon
Brandon Buffin
You can change the SIP port on the CME with the following commands:
sip-ua
listen-port
Be aware that this is a global configuration. All SIP dial peers will use the new port for SIP communications.
Hope this helps.
Brandon
hi, but i dont need to change the listen port on the ccme, i need to send the ccme trafic to the port 5061.....because the ccm has configured to listen this port..... in resume, i need to send the SIP outgoing traffic from the ccme using the 5061 port
Hope this helps.
Brandon
