SIP Trunk between CME and CUCM 7.x
Dear All
Is there any document available from Cisco to configure SIP trunk between CME and CUCM 7.x
Also want to know corporate direcory can be merged between CME and CUCM?
1 REPLY
Re: SIP Trunk between CME and CUCM 7.x
As with H323, all you need is a SIP dial peer pointing to the CUCM with the destination pattern of what you want to dial and on CUCM configure a SIP trunk pointing to the CME router.
You'd need to create a custom directory to merge the directories from the system as there is no native way
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1666
