SIP Trunk between CUCM 8.5 and CME calling outbound fails
Hello all,
I am trying to setup a SIP Trunk between CUCM 8.5 and CME.  Calling outbound to CUCM is failing with a code of SIP /2.0 503 Service Unvailable.  I can receive inbound calls from the CUCM.
Here is the call flow.
Phones(third-party)--SIP--2901(CME) --SIPtrunk--CUCM--MGCP--PSTN
1 ACCEPTED SOLUTION
Re: SIP Trunk between CUCM 8.5 and CME calling outbound fails
Hi Matthew,
The CUCM server is requesting that the gateway authenticate using Digest Authentication.
You have a couple of options. If you don't want to use Digest Authentication on this trunk, you can uncheck the "Enable Digest Authentication" tick box on the SIP trunk security profile assigned to the SIP trunk used by CME. (Make sure that this profile is not used by any other SIP trunks first)
if you need to use Digest Authentication, create an application user e.g "cmeTrunk" and assign a password in the "Digest Credentials" box then on your CME router add the following commands:
sip-ua
authentication username cmeTrunk password
Dave
Hall of Fame Super Silver
Can you please post full "debug ccsip messages"?
What are you calling, PSTN number or internal phone DN on CUCM?
Do you have proper CSS applied to the trunk on CUCM?
What IOS are you using on CME?
Can you post your config?
Chris
Log Buffer (10000000 bytes):
Apr  3 17:11:54.614: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2194@10.181.38.156 SIP/2.0
Via: SIP/2.0/UDP 10.99.57.85:31270;branch=z9hG4bK-d8754z-2c106c8bfd6f49be-1---d8754z-;rport
Max-Forwards: 70
Contact: <4966>
To: <2194>
Call-ID: NmIyNzM3MjBhYjMzZmYxMTQyYzA4OGViNTRiMTNhZjE.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
Content-Type: application/sdp
Supported: replaces
User-Agent: X-Lite 4 release 4.1 stamp 63214
Content-Length: 402
v=0
o=- 12977946714729921 1 IN IP4 10.99.57.85
s=CounterPath X-Lite 4.1
c=IN IP4 10.99.57.85
t=0 0
a=ice-ufrag:8bc311
a=ice-pwd:4e323f2f026316cd3b630b8fb6c1e20d
m=audio 54592 RTP/AVP 107 0 8 101
a=rtpmap:107 BV32/16000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=candidate:1 1 UDP 659136 10.99.57.85 54592 typ host
a=candidate:1 2 UDP 659134 10.99.57.85 54593 typ host
Apr  3 17:11:54.626: //154/F23B99DC814F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <2194>
Date: Tue, 03 Apr 2012 17:11:54 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Apr  3 17:11:54.626: //155/F23B99DC814F/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:2194@10.111.38.112:5060 SIP/2.0
Via: SIP/2.0/UDP 10.181.38.156:5060;branch=z9hG4bK5AF06
To: <2194>
Call-ID: F23CD2C4-7CE611E1-81559B2A-690F2E09@10.181.38.156
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 4063992284-2095452641-2169477930-1762602505
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1333473114
Contact: <4966>
Expires: 180
Max-Forwards: 69
P-Asserted-Identity: "Matthew Michaluk" <4966>
Content-Disposition: session;handling=required
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 9190 378 IN IP4 10.181.38.156
s=SIP Call
c=IN IP4 10.181.38.156
t=0 0
m=audio 25532 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-16
a=ptime:20
Apr  3 17:11:54.630: //155/F23B99DC814F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <2194>
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Received:
SIP/2.0 401 Unauthorized
To: <2194>;tag=615455654
CSeq: 101 INVITE
WWW-Authenticate: Digest realm="SHU-CM-1-Cluster", nonce="Q61+fGJ2njtkfatuaC3iLIZeezqloJ1H", algorithm=MD5
Content-Length: 0
Apr  3 17:11:54.634: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:2194@10.111.38.112:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Apr  3 17:11:54.634: //156/F23B99DC814F/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:2194@10.181.38.112:5060 SIP/2.0
Via: SIP/2.0/UDP 10.181.38.156:5060;branch=z9hG4bK5B237D
To: <2194>
Call-ID: F23EA73C-7CE611E1-81579B2A-690F2E09@10.181.38.156
Min-SE:  1800
CSeq: 101 INVITE
Contact: <4966>
Expires: 180
Max-Forwards: 69
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 9394 7124 IN IP4 10.181.38.156
s=SIP Call
t=0 0
m=audio 21286 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Apr  3 17:11:54.638: //156/F23B99DC814F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <2194>
CSeq: 101 INVITE
Content-Length: 0
Received:
To: <2194>;tag=693622302
CSeq: 101 INVITE
WWW-Authenticate: Digest realm="SHU-CM-1-Cluster", nonce="YBPjY4DiQzDJECmOMIw3EaKgJ/kaAySh", algorithm=MD5
Content-Length: 0
Apr  3 17:11:54.646: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:2194@10.181.38.112:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Apr  3 17:11:54.646: //157/F23B99DC814F/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.181.38.156:5060;branch=z9hG4bK5C437
To: <2194>
Call-ID: F23FDF8C-7CE611E1-81599B2A-690F2E09@10.181.38.156
Min-SE:  1800
CSeq: 101 INVITE
Contact: <4966>
Expires: 180
Max-Forwards: 69
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 8292 5511 IN IP4 10.181.38.156
s=SIP Call
t=0 0
m=audio 21846 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Received:
SIP/2.0 100 Trying
To: <2194>
CSeq: 101 INVITE
Content-Length: 0
Received:
To: <2194>;tag=962362618
CSeq: 101 INVITE
Content-Length: 0
Apr  3 17:11:54.654: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Apr  3 17:11:54.654: //158/F23B99DC814F/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.181.38.156:5060;branch=z9hG4bK5DACB
To: <2194>
Call-ID: F2411875-7CE611E1-815B9B2A-690F2E09@10.181.38.156
Min-SE:  1800
CSeq: 101 INVITE
Contact: <4966>
Expires: 180
Max-Forwards: 69
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 3361 1012 IN IP4 10.181.38.156
s=SIP Call
t=0 0
m=audio 27742 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Received:
SIP/2.0 100 Trying
To: <2194>
CSeq: 101 INVITE
Content-Length: 0
Apr  3 17:11:54.658: //158/F23B99DC814F/SIP/Msg/ccsipDisplayMsg:
Received:
To: <2194>;tag=1156190691
CSeq: 101 INVITE
Content-Length: 0
Apr  3 17:11:54.658: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Apr  3 17:11:54.658: //154/F23B99DC814F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <2194>;tag=4C19D08-D71
CSeq: 1 INVITE
Reason: Q.850;cause=47
Content-Length: 0
Apr  3 17:11:54.710: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:2194@10.181.38.156 SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
Apr  3 17:12:13.262: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:113478650916@10.181.38.156 SIP/2.0
Via: SIP/2.0/UDP 10.99.57.85:31270;branch=z9hG4bK-d8754z-9d6411f50414b3e5-1---d8754z-;rport
Max-Forwards: 70
Contact: <4966>
To: <113478650916>
Call-ID: MzFkYjgwMWVmZmJlOWU0NjQ1N2FkZGJmMWQxYmRlNzM.
CSeq: 1 INVITE
Supported: replaces
Content-Length: 402
v=0
o=- 12977946733373191 1 IN IP4 10.99.57.85
t=0 0
a=ice-ufrag:be6cd9
a=ice-pwd:868d1fa4176edb618ed024e0a42906da
m=audio 55146 RTP/AVP 107 0 8 101
a=fmtp:101 0-15
a=sendrecv
a=candidate:1 1 UDP 659136 10.99.57.85 55146 typ host
a=candidate:1 2 UDP 659134 10.99.57.85 55147 typ host
Apr  3 17:12:13.270: //159/FD590EAF815C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <113478650916>
Date: Tue, 03 Apr 2012 17:12:13 GMT
CSeq: 1 INVITE
Content-Length: 0
Apr  3 17:12:13.270: //160/FD590EAF815C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:113478650916@10.111.38.112:5060 SIP/2.0
Via: SIP/2.0/UDP 10.181.38.156:5060;branch=z9hG4bK5E18E8
To: <113478650916>
Call-ID: FD5A4797-7CE611E1-81629B2A-690F2E09@10.181.38.156
Min-SE:  1800
Cisco-Guid: 4250472111-2095452641-2170329898-1762602505
CSeq: 101 INVITE
Timestamp: 1333473133
Contact: <4966>
Expires: 180
Max-Forwards: 69
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 6724 930 IN IP4 10.181.38.156
s=SIP Call
t=0 0
m=audio 29746 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Apr  3 17:12:13.274: //160/FD590EAF815C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <113478650916>
CSeq: 101 INVITE
Content-Length: 0
Received:
To: <113478650916>;tag=2135384412
CSeq: 101 INVITE
Content-Length: 0
Apr  3 17:12:13.278: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:113478650916@10.111.38.112:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Apr  3 17:12:13.278: //161/FD590EAF815C/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.181.38.156:5060;branch=z9hG4bK5F8C0
To: <113478650916>
Call-ID: FD5B7FE7-7CE611E1-81649B2A-690F2E09@10.181.38.156
Min-SE:  1800
CSeq: 101 INVITE
Contact: <4966>
Expires: 180
Max-Forwards: 69
Content-Length: 248
v=0
o=CiscoSystemsSIP-GW-UserAgent 77 7007 IN IP4 10.181.38.156
s=SIP Call
t=0 0
m=audio 30294 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Apr  3 17:12:13.282: //161/FD590EAF815C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <113478650916>
CSeq: 101 INVITE
Content-Length: 0
Received:
To: <113478650916>;tag=492895608
CSeq: 101 INVITE
Content-Length: 0
Apr  3 17:12:13.286: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Apr  3 17:12:13.286: //162/FD590EAF815C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:113478650916@10.181.38.112:5060 SIP/2.0
Via: SIP/2.0/UDP 10.181.38.156:5060;branch=z9hG4bK6083F
To: <113478650916>
Call-ID: FD5CB837-7CE611E1-81669B2A-690F2E09@10.181.38.156
Min-SE:  1800
CSeq: 101 INVITE
Contact: <4966>
Expires: 180
Max-Forwards: 69
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 5730 7312 IN IP4 10.181.38.156
s=SIP Call
t=0 0
m=audio 19898 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Apr  3 17:12:13.290: //162/FD590EAF815C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <113478650916>
CSeq: 101 INVITE
Content-Length: 0
Received:
To: <113478650916>;tag=1807123680
CSeq: 101 INVITE
Content-Length: 0
Apr  3 17:12:13.294: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:113478650916@10.181.38.112:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Apr  3 17:12:13.294: //159/FD590EAF815C/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <113478650916>;tag=4C1E5D4-2F0
CSeq: 1 INVITE
Content-Length: 0
Apr  3 17:12:13.298: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:113478650916@10.181.38.156 SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
is the IOS 15.1 or newer?
if so add the following:
voice service voip
no ip address trusted authenticate
If not, the message here that is important is:
so, make sure CSS applied to trunk has access to the 2194 DN's parition.
HTH,
Chris
flash0:c2900-universalk9-mz.SPA.151-4.M3.bin
Do you mean for inbound call section
Inbound Calls
Required Field
Required Field
Required Field
OK, applying the following should fix it:
voice service voip
HTH, please rate all useful posts!
Chris
I tried that and no luck.  It is in the right calling search space.
Hi Matthew,
sip-ua
Dave
1508
