SIP Trunk -- Cisco 29XX -- MS Lync
Hi All,
I was wondering if I could have some assistance with a setup that seems to be causing a whole lot of pain. Looking at messages in Debug (CCSIP Messages) It appears inbound calls come in from our ITSP but the Cisco is then trying to route them back to them NOT the MS Lync.
Outbound calls work
Incoming do not
The voice config is attached.
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
address-hiding
mode border-element
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
signaling forward unconditional
fax protocol pass-through g711alaw
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  session transport tcp
  header-passing
  error-passthru
   outbound-proxy dns:sip.provider.co.uk
  early-offer forced
  midcall-signaling passthru
voice class codec 711
codec preference 1 g711alaw
codec preference 2 g729r8
codec preference 3 g711ulaw
voice class sip-profiles 1
request ANY sip-header Cisco-Guid remove
response ANY sip-header Cisco-Guid remove
request ANY sip-header Remote-Party-ID modify "@.*>" "@sip.provider.co.uk>"
response ANY sip-header Remote-Party-ID modify "@.*>" "@sip.provider.co.uk>"
request INVITE sip-header Referred-By remove
voice translation-rule 1
rule 1 /0/ /44/
rule 2 /^0/ /44/
voice translation-profile Correct_Outwards
translate calling 1
dial-peer voice 100 voip
description TO SP
translation-profile outgoing Correct_Outwards
huntstop
preference 2
max-conn 5
destination-pattern .T
progress_ind setup enable 3
session protocol sipv2
session target sip-server
voice-class codec 711
dtmf-relay rtp-nte
dtmf-interworking rtp-nte
no vad
dial-peer voice 200 voip
description TO LYNC
preference 1
destination-pattern 441234567890
session target ipv4:10.112.40.198:5068
incoming called-number .
voice-class sip dtmf-relay force rtp-nte
no voice-class sip outbound-proxy
dtmf-relay sip-notify
codec g711alaw
no vad
gateway
timer receive-rtp 1200
sip-ua
credentials username uuuuuuu password pppppp realm test.org
authentication username uuuuuuu password pppppp realm test.org
no remote-party-id
set pstn-cause 47 sip-status 486
retry invite 2
retry response 3
retry bye 3
retry prack 6
timers expires 300000
registrar dns:sipprovider.co.uk expires 3600
sip-server dns:sipprovider.co.uk connection-reuse
host-registrar
What appears to be wrong.
Hall of Fame Super Gold
No debug messages are posted, however mormally that happens when you have a wrong dial-peer configuration.
Hall of Fame Super Silver
No attachment.
Chris
Re: SIP Trunk -- Cisco 29XX -- MS Lync
                 Debug is now attached. Sorry
You are calling 441733311111, yet your dial peer to Lync has different specific destination pattern, so not sure how you expect it to go where you want. Since your 100 dial-peer catches all ".T" it will attempt to go out that way. Use "debug voice dialpeer" to see if proper dial-peer is matched for your testing.
Chris
Apologies, I tried to null the config a little. The destination is the same as the number I am calling.
The call is attempting to go to 10.112.40.240 where it fails, what is that IP? Can you post "debug voice dialpeer"?
Chris
Try adding the sip bind control to the inbound dial-peer.
dial-peer voice xxx voip
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
557
