SIP trunk, CUBE and CUCM 8.5
pjiracek
I have a SIP trunk from a TSP terminated on the CUBE. - c2901 gateway connected via H323 to a CUCM 8.5 cluster. The signalling looks OK but I have no voice. The provider seems to support only G.729br8 codec and my phones (c6901 and c6921) seem to talk G.729r8 only so I need to do some transcoding. I'm in the UK btw.Now, I can do it on the CUBE and utilize dspfarm but that is I think only possible with SCCP. How do I register the gateway in CUCM, if it's already there as the H323 gateway?
Is there any way to do the transcoding on the CUCM? Any general advise would be much appreciated.
Cheers
3 Accepted Solutions
Ok,
You still have not configured the dial-peer to CUCM to use SIP. But here is what I see..
Sent:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 146.191.243.4:6280;branch=z9hG4bK7kljtp2088b0cmgv34l0.1
To: <5811>;tag=44F7878-C23
Date: Wed, 27 Jun 2012 09:38:06 GMT
Call-ID: ODE1Y2E4ZTlhZDg1NjM0MmRhZDE4YmNhNTRiMjhkN2M.
CSeq: 1 INVITE
Require: 100rel
RSeq: 650
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Remote-Party-ID: "Michelle  Walters" <5811>;party=called;screen=no;privacy=off
Contact: <5811>
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 262
v=0
o=CiscoSystemsSIP-GW-UserAgent 5886 9981 IN IP4 146.191.201.41
s=SIP Call
c=IN IP4 146.191.201.41
t=0 0
m=audio 20748 RTP/AVP 18 96
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:96 telephone-event/8000
a=fmtp:96 0-16
You are sending G729br8 to your provider but they do not support annexb because in their invite we do not see annexb.
INVITE sip:5811@UniWestScot:5060 SIP/2.0
Max-Forwards: 68
Contact:
To: <5811>
CSeq: 1 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, REFER, PRACK
Supported: 100rel
P-Asserted-Identity:
Content-Length: 278
v=0
o=Redwood_INX 347015 347015 IN IP4 146.191.243.4
s=Redwood Media Server
c=IN IP4 146.191.243.4
t=0 0
m=audio 50002 RTP/AVP 8 18 96
a=rtpmap:8 PCMA/8000
a=sendrecv
a=silenceSupp:off
a=ecan:on
a=fmtp:96 0-15
So either configure your cube to transcode from g729br8 to g729r8 or send your provider g729r8
Here is the document to use to setup xcoding on your cube..
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a008092d6b3.shtml
Ensure you add g729br8 in your list of codecs
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
I have looked at the trace in detail and I have an idea why this is not working..
Can you please remove this from your dial-peers to cucm. Please ensure you remove from all dial-peers to cucm and sip provider.
progress_ind setup enable 3
progress_ind alert enable 8
Please do another test call and send me debug ccsip messages.
The reason why this is not working is because the called number is not 5811 from the sip provider..
Your dial-peer 1 is like this..
dial-peer voice 1 voip
  incoming called-number 5[8-9].. (this is not the incoming called number)
it should be this..
incoming called-number 01387345[8-9]..
Then when this dial-peer is matched, the xlation will be applied.
49 Replies 49
Ayodeji Okanlawon
I doubt if yourprovide ronly support G729br8. Most providers support a variety of codecs. You can turn on "debug ccsip messages" on your cube and see what codecs your provider is sending to you..
I will suggest you start with this before going down the xcoding route
Have had a look already. The provider offers PCMA/8000 and G729/8000 codecs which seem to translate to g711a and g729br8 in cisco speak. And the flavour g729br8 is not liked by our phones.
OK, I've progressed a bit - our phones should do g729br8 so no transcoding needed.
I still cannot get any voice. I have the right codec set up on the CUBE for the SIP trunk and for the CUCM.(g729br8)
I have the CUBE and the phones in regions set up for G.729.
One thing - my CUBE is just an IP host (with 1 ethernet interface) and I have no ip routing. It's on a remote site so I cannot easily turn it on - but I cannot think it would make a difference.
So now I have only g729br8 codec on the CUBE gateway. I make a inbound call over the SIP trunk, phone rings, when I pick it up (no audio) I can check the Sender codec = G711u and RCVR codec =G711u on the phone. What's going on? The phone is in a different region than the CUBE and the Max Audio bit rate between the 2 regions is 8kbps -> G729. Why does the phone insist on G711u?
Hi pijaracek,
Look like is not a CODEC negotiation problem because the call is established. Are you using Media Flow around or Passtrought?
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
No media flow,
I have only
fax protocol pass-through g711ulaw
I'm starting to suspect the config of the gateway in CUCM needs some change
Please post your show run
Here is the sh run on the CUBE:
I am not sure why you want help but you dont want to send over the things that can be used to help. I asked earlier for "debug ccsip messages". If you want us to help..please send the debug and your sh run.
Sorry, I didn't get yoy asked for the debug. Here it is:
pjiracek
I suspect now the SIP trunk and the CUBE configuration is OK.
For inbound calls over the SIP trunk I cannot hear the ringing tone although the phone is ringing and then if I redirect in CUCM using
Forward No Answer External
to Voicemail or another internal number, suddenly it works - the redirected call is ringing and there is audio after pick up.
Anything I should try to change in CUCM H323 gateway configuration?
It looks like this:
Hi first of all I will advise to tidy up your configuration. This two dial-peers are not right.
dial-peer voice 2 voip
description *** INBOUND VOIP PEER ***
incoming called-number .
voice-class codec 1
dtmf-relay h245-alphanumeric
fax rate disable
ip qos dscp cs3 signaling
no vad
description *** INBOUND SIP TRUNK PEER ***
translation-profile incoming SIP-TRUNK-IN
session protocol sipv2
session target ipv4:XXX.XXX.243.4
voice-class codec 2
dtmf-relay rtp-nte
no vad
Both dial-peers are used for inbound calls from CUCM and from your SIP provider. Your sip provider sends a sip leg and one of these dial-peers is doing a h323 leg. I will advise that you either configure a specific dial-peer to match incoming calls from your sip provider and configure sip protocol on that dial-peer or you configure a single dial-peer with incoming called number. and session protocl sip. Then configure a sip trunk from your cucm to your cube.
So before we troubleshoot further, please do what I suggest.
The best scenario is to have an and to end sip solution like this..
CUCM-----SIP Trunk--->CUBE------>ITSP.
To do this, you need to configure a sip trunk on cucm to CUBE and then configure this interface like this..(make the IP on the destination siup trunk to be=ip of gig0/1)
voice service voip
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
After configuring this then configure the ff:
description *** INBOUND DIAL-PEER ***
voice-class codec 2
dtmf-relay rtp-nte
no vad
no dial-peer voice 2 voip (remove this dial-peer).
Do a test call and send debug ccsip messages.
If you want to stick with the h323 scenario, your call flow will look like this..
cucm----h323----CUBE---sip--->ITSP
You need to configure the ff: in addition to what you have now
h323-gateway voip interface
description *** INBOUND SIP TRUNK DIAL-PEER ***
voice-class codec 2
dtmf-relay rtp-nte
no vad
voice-class codec 1
fax rate disable
no vad
Thanks for the reply.
I'd like to keep the h323 - sip scenario. So I changed the config as you suggested (I think in dial-peer voice 2 voip you missed session target clause). It still doesn't work. There is no dial tone for the inbound calls, although the phone rings and the call can even be successfully redirected and it rings once for the outbound calls and then the CUBE cancels the call and there is busy tone.
Here is the inbound call debug:
Need to check the config but the symptoms are like the call is matching default dial peer
