Sip Trunk CUCM /ASA/ ITSP
Hello
I have an sip trunk with an ITSP in CUCM, thats is the flow:
IP Phone -> CUCM -> SIP TRUNK  -> ASA -> ITSP
The outbound call is established but has no audio.
On ASA has a NAT from the outside interface do CUCM IP address
When the audio is established, is from CUCM to the SIP Proxy?
Inbound calls are not established
SIP/2.0 503 Service Unavailable
Via: SIP/2.0/UDP 66.33.147.146:5060;branch=z9hG4bK_1128038047_8107_1
From: <sip:000121263600@66.33.147.146:5060>;tag=1128038047_C
To: <sip:2766@192.168.10.210:5060>;tag=1599180641
Date: Mon, 13 Jan 2014 19:46:11 GMT
Call-ID: sbcsipuac.2_206.20.7.11_b12sb09_1_1_2014011314433251_1128038047_218711
CSeq: 1001 INVITE
Allow-Events: presence
Warning: 399 SRVRCUCMPUB "Unable to find a device handler for the request received on port 5060 from 66.33.147.146"
Content-Length: 0
Leonardo Santana
2 ACCEPTED SOLUTIONS
VIP Super Bronze
This error "Warning: 399 SRVRCUCMPUB "Unable to find a device handler for the request received on port 5060 from 66.33.147.146" suggests that CUCM is receiving traffic from an ip address that is not configured on the sip trunk facing the ITSP..
What is the ip address that you have specified on the sip trunk?
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
I suggest you look at the firewall here..Check that you have ip routing to the ip address where media is terminated..Check your ASA logs, something is not right there
Have a look at the following Thread
https://supportforums.cisco.com/thread/276600
Voice CCIE #37771
VIP Super Bronze
Hello
For the inbound calls a found the issue, the ITSP have differents IPs Address to receive and make the call.
I created an specif SIP Trunk for inbound and one for outbound, the calls are now established but both (inbound and outbound) with no audio.
Leonardo Santana
VIP Super Bronze
I will check that, IP Routing is enabled from the voice network i can reach the SIP Proxy Address, but i think the RTP is blocked, i ask the Security Team to check this.
Thanks again.
Leonardo Santana
Leanardo suggested IP Routing which is one thing to check.  The next thing to check is the sip inspection rules. Doing SIP Inpection on an ASA for this type of design can cause you issues..  So you might want to turn that off in the ASA as well.
464
