SIP Trunk Digest Authentication
Hello everyone,
I have been having trouble trying to get SIP Trunk authentication to work.
Im trying to use this as a way of monitoring which trunks are up and down with the end-state and possibly in the future, to be able to display this graphically (using api I guess).
Im not even sure if this is possible so if someone has a better idea on how to achieve this please let me know.
I have tried using RTMT to watch trunks but from what I can see it cant handle the amount of trunks that I would like to watch, in the range of 90 odd.
I have read Cisco Unified Communications Manager Security Guide, Release 8.5(1) and while it explains how to get it working, it does so in a very vague manner.
I have CUCM 8.5 set with a Sip trunk security profile using tcp in and out, with the security mode non secure and enable digest auth ticked.
I have created an application user with all details the same eg, name=siptest, digest=siptest and password=siptest.
I have created a sip trunk and tested sucessfully with digest auth turned off.
on CUCME I have the following config:
--------ommitted-----------
voice service voip
allow-connections sip to sip
fax protocol cisco
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  asymmetric payload full
---------ommitted-----------
dial-peer voice 100 voip
description Inbound Dial Peer
voice-class codec 1
session protocol sipv2
session transport tcp
incoming called-number 7000.
dtmf-relay rtp-nte
dial-peer voice 200 voip
description To CUCM
destination-pattern .T
voice-class codec 1
session target sip-server
dtmf-relay rtp-nte
no vad
sip-ua
credentials username siptest password 7 105D00091112011F realm ccmsipline
authentication username siptest password 7 120A0C07060E1F10 realm ccmsipline
registrar ipv4:10.0.0.1 expires 3600
sip-server ipv4:10.0.0.1
----------ommitted-----------
Debug ccsip messages gives me this output:
Jul  3 01:57:58.727: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:10.0.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.8:5060;branch=z9hG4bKB2A
To: <sip:siptest@10.0.0.1>
Date: Tue, 03 Jul 2012 01:57:58 GMT
Call-ID: 5915ED5F-C3E911E1-969887E9-991716BF
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1341280678
CSeq: 2 REGISTER
Contact: <sip:siptest@192.168.1.8:5060>
Expires:  3600
Content-Length: 0
Jul  3 01:57:58.731: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 2 REGISTER
Content-Length: 0
Jul  3 01:57:58.831: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <sip:siptest@10.0.0.1>;tag=1091711221
CSeq: 2 REGISTER
WWW-Authenticate: Digest realm="ccmsipline", nonce="d5MiGcCRT11J+/Wki1jY0hCR0lOFv3oI", algorithm=MD5
Content-Length: 0
Jul  3 01:57:58.835: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.8:5060;branch=z9hG4bKC201B
Max-Forwards: 70
CSeq: 3 REGISTER
Expires: 3600
Authorization: Digest username="siptest",realm="ccmsipline",uri="sip:10.0.0.1:5060",response="cce7435918ed64d08eeb6e574e7d4550",nonce="d5MiGcCRT11J+/Wki1jY0hCR0lOFv3oI",algorithm=MD5
Content-Length: 0
Jul  3 01:57:58.843: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 3 REGISTER
Content-Length: 0
Received:
SIP/2.0 404 Not Found
CSeq: 3 REGISTER
Warning: 399 CMPUB01 "Unable to find device/user in database"
Content-Length: 0
Anyone have any ideas?
Thanks in advance.
913
