10-02-2014 12:14 AM - edited 03-17-2019 12:24 AM
hello
I have cucm version 9.1.2.12900-11.
when I calling via sip trunk to menu, the DTMF doesn't work
through pri it works .
I tried to change setting in sip trunk (dtmf signaling method) and it is not working
Please advise.
thank you
10-02-2014 12:53 AM
what is the call flow?
CUCM---sip---CUBE---sip---Provider?
what is the DTMF method set on the CUCM SIP Trunk configuration?
if it is CUBE, what is the dtmf method configured on the inbound & outbound dial-peers?
10-02-2014 01:04 AM
CUCM---sip---Box ---Provider
Dtmd signaling Method:OOB and RFC 2833
10-02-2014 01:09 AM
I assume the Box you mean here is Cisco Gateway (CUBE).
can you post the running config? what is the dtmf method your provider expects to receive?
can you collect "debug ccsip message" and post the log?
10-02-2014 01:31 AM
The box doesn't Cisco Gateway.
i dont access to box.
10-02-2014 01:35 AM
Perhaps, you should try setting 'RFC2833' first in the CUCM SIP Trunk or 'No Preference.
You can collect CCM Traces and check what is the DTMF negotiated between CUCM & the Box.
10-02-2014 01:54 AM
I change setting and DTMF doesn't work.
