Silver
SIP trunk early offer
We have configured a trunk with a provider using CUBE.
Callmanager--------CUBE--------Provider
The provider wants early offer and G729r8
So we configured a SIP trunk with a device pool/region so that only g729 is allowed between SIP trunk and the rest.
We have configured an IOS MTP resource, and this is registered on callmanager:
dspfarm profile 2 mtp
codec g729r8
maximum sessions software 20
associate application SCCP
The mtp resource is assign to the trunk using MR-list and MR-group
The trunk has MTP enabled with "MTP prefered Codec" G729b/G729ab
On CUBE we enable "deb ccsip mess" and we see the invite comming from callmanager, but without attached SDP
What must be done to make callmanager use early-offer?
Thanks for the help,
Jan
Everyone's tags (1)
Re: SIP trunk early offer
Check MTP required on the SIP trunk configuration page or if you are on CUCM 8.5 or later go to the SIP Profile (Device > Device Settings > SIP Profile) and check "Early Offer support for voice and video calls (insert MTP if needed)".
Silver
Hello Joe,
I have MTP required enabled on the trunk, but it doesn't really change anything.
If I enable, or don't enable "MTP required" the SIP INVITE from callmanager is the same.
We are running Callmanager 7.1.5, so we don't have the option in the SIP profile.
When we establish a call I can see that the IOS MTP is involved (show sccp connections) but no early offer.
To make a successfull cal we force the provider dial-peer to use G729 only.
Unfortunately this IOS doesn't have the forced early offer option.
Is there someone who has succeeded in making CM 7.1.5 do an early offer?
Jan
Hi Jan,
Here is your answer
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/media.html#wp1055833
Snippet from above
SIP Early Offer
SIP negotiates media exchange via Session Description Protocol (SDP),  where one side offers a set of capabilities to which the other side  answers, thus converging on a set of media characteristics. SIP allows  the initial offer to be sent either by the caller in the initial INVITE  message or, if the caller chooses not to, the called party can send the  initial offer in the first reliable response. By default, Unified CM  sends the INVITE without an initial offer, and it requires MTP resources  to send the offer in the INVITE. Note that this initial offer is  limited to the G.711 codec only.
Also note that MTP resources are not required for incoming INVITE messages, whether or not they contain an initial offer.
Niket
Silver
Hi Niket,
You seem to be right, when I force 711 I see early offer.
But it is weird that on the trunk configuration page, it allows me to select a g729 codec as prefered codec.
Can you explain why this option is there, although it doesn't sem to work?
Thanks for your help,
Jan
Hi Jan,
I dont know whats the logic and i dont have a confirmed answer, behind not supporting the g729 codec in CM 7.1.5 , however when i open the SRND for CM 8.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/trunks.html#wp1126420
I dont see any requirements on the codec.
So somewhere between CM 7.x and CM 8.x there must be a fix for supporting the g729 codec on early offer.
Hope this helps.
Niket
Silver
Hi Niket,
Thank you very much.
We are testing now with another router that has an IOS which supports 'SIP early offer forced' and we hope that this will work.
So the callmanager will send a normal INVITE (delayed offer) and the CUBE will send out a early offer to the provider.
Jan
VIP Super Bronze
J,
Did the early offer-forced work?
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Silver
We haven't configured yet. I shall let the community know.
Thanks for all,
Jan
VIP Super Bronze
J,
I just saw your query on the ask the expert forum. I thought I should chip in here for you.
Yes CUCM can send delay offer and CUBE can send early offer. This is how we have it configured for one of my biggest customers with 3 clusters (8 server/cluster) and it works very well...
Here is a snippet from our CUBE config..
sip
early-offer forced.
Here is a sample trace..
+++++CUCM sends invite without early offer+++++++++
Received:
INVITE sip:07544455678@172.16.10.74:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.10.174:5060;branch=z9hG4bKa41e64e002602
From: "Chelmsford" <01256748210>;tag=517285~ffa80926-5fac-4dd6-b405-2dbbc56ae9a2-400694295
To: <07544455678>
Date: Mon, 18 Jun 2012 09:46:00 GMT
Call-ID: 67d44180-fde1f8d8-3aead-ae28690a@172.16.10.174
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <172.16.10.174:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 1741963648-0000065536-0000064326-2921883914
Session-Expires:  84600
Contact: <01256748210>
Max-Forwards: 70
Content-Length: 0
++++++++++++++CUBE sends a trying to CUCM++++++++++++++++
Sent:
SIP/2.0 100 Trying
To: <07544455678>
CSeq: 101 INVITE
Allow-Events: kpml, telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
+++++++++CUBE sends an invite to ITSP with Early Offer++++++++++
010625: Jun 18 09:46:00.371: //452987/67D441800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:07544455678@10.100.33.54:5070 SIP/2.0
Via: SIP/2.0/UDP 172.16.10.74:5060;branch=z9hG4bKFE71F2421
Remote-Party-ID: "Chelmsford" <441256748210>;party=calling;screen=no;privacy=off
From: "Chelmsford" <441256748210>;tag=88EFEFBA-14A2
To: <07544455678>
Call-ID: 3EDB1C4A-B86111E1-94E48F4D-5D7E5E41@172.16.10.74
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1340012760
Contact: <441256748210>
Expires: 180
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 354
v=0
o=CiscoSystemsSIP-GW-UserAgent 6030 604 IN IP4 172.16.10.74
s=SIP Call
c=IN IP4 172.16.10.74
t=0 0
m=audio 18110 RTP/AVP 18 0 8 100 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
Silver
Thank you very much!
We are going to configure it like this.
Unfortunately one of our CUBE router has not the forced SIP early offer command, and we need to install more flash and memory and then do an IOS upgrade.
We now make a test with a 2811 that has the correct IOS, but this router has such a weird issue that I think I have to open a TAC case. In this router I can not apply the "bind control source-interface" command. I can type it, but the"show run" doesn't show it. So weird.
We did format flash, install another IOS, but it doesn't apply the bind commands.
Thanks!
Jan
VIP Super Bronze
How did you apply the command..Is it like this..
sip
  bind control source-interface gig0/0
  bind media source-interface gig0/0
Silver
Exactly!
but in the show run we don't see it
Jan
VIP Super Bronze
What IOS version are you running?
Silver
c2800nm-ipvoice_ivs-mz.124-20.T6.bin
c2800nm-adventerprisek9-mz.124-24.T7.bin
c2800nm-adventerprisek9-mz.124-24.T4.bin
c2800nm-adventerprisek9-mz.124-24.T5.bin
Pick one
We tried all of them.
Jan
VIP Super Bronze
Can you send the output of this command..
show sip-ua status
Silver
At this moment I have removed this router from customer site, and it is in my office.
We got crazy about this router not accepting the bind commands.
But regardless of configuration, the bind commands should be accepted I think.
Jan
Hi Aokanlawon,
I have the similar problem:
My scenario:
CUCM 9X -->SIP TRUNK--> CUBE --> ISP SIP
I need invite Early Offer to ISP, for DTMF problems, I don´t like the use CUCM fot this.
I set in CUBE (early-offer forced), but if I removed pass-thru content sdp, i received fas busy and CUCM return Internal Server Error:
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  early-offer forced
  midcall-signaling passthru
  pass-thru headers unsupp
  no call service stop
how can I solve this?
Thanks!
Joao
VIP Super Bronze
Can you do a test call and send us "debug ccsip messages" attach it here
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Attached Log in last post.
Joao
VIP Super Bronze
The log you attached was a succesful call and your cube didnt send EO to your ITSP. I didnt see any error in the log
In this case not have problem, is correct.
But in some calls the ISP don´t invite SDP payload with DTMF information (telephone event) and DTMF fails in this case.
I attached log problem.
Thanks.
Joao
VIP Super Bronze
There is nothing you can do, if your ITSP doesnt advertise any DTMF capabilites in their SDP. You need to contact them and have it corrected. CUBE can only respond to what is offered. This is a problem with them so get them to sort it out
Hi.
I remove the SIP configs below for invite SDP EO to ISP.
sip
and use (early-offer forced)
The ISP response with payload complete in this case, I dialed the same number with problems, but my call rinring and return a fast busy in this case, CUBE return internal server error for CUCM.
Sent:
SIP/2.0 500 Internal Server Error
Via: SIP/2.0/TCP 21.10.0.7:5060;branch=z9hG4bK13eb293705d2
From: "ATA187 Core" <6001>;tag=21576~fb89236f-816b-47f5-8c94-b8d3c388dd7c-64665064
To: <297840042484>;tag=3E21E738-DD8
Date: Mon, 02 Sep 2013 21:44:24 GMT
Call-ID: 263d9280-22510742-b70-7000a15@21.10.0.7
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M3
Reason: Q.850;cause=96
Content-Length: 0
VIP Super Bronze
You need to post the full debug, for us to know whats happening. Cause code 96 means that a madatory IE is missing
Typical scenarios include:
  • Mandatory Contact field missing in SIP message.
  • Session Description Protocol (SDP) body is missing.
So until I see the full log, I wont know what is wrong
Attached logs with error 96 for you analise.
I don´t see the SDP payloads.
Thanks for help.
Joao
Well, in this case (error code 96) the service provider is:
a. removig the SDP in the subsequent 180 Ringing
b. not including an SDP in the 200 OK
That's why the router spits out cause code 96.
Talk to the Service Provider, I would suggest...
cheers,
Jan
Hi Ayodeji,We have the
Hi Ayodeji,
We have the following setup:
Phones-- PBX--- Voice gateway --- SIP provider
When we try to make any outbound call, call gets connected and when the destination end receives the call the call gets disconnected.
It shows the cause 16 of disconnecting the call.
As I have searched for it, I found that call is cleared normally. But we haven't cleared call.
When I have checked the debugs on Voice Gateway. I have found that when we make any outboud call then after registration, we receive 183 Session progress message from the SIP provider. After that SDP message send from our end.
It looks like that the SIP provider is using early offer and on our end delay offer is running.
Can you please tell me if one voice gateway is using delay offer and the SIP provider will be using early offer then what will happen?
Does the call be successful or it has got connected?
Regards;
MUKESH KUMAR | Network Engineer
Spooster IT Services
Computer Networking Solutions
Which PBX?
Which PBX?
Which voice gateway?
It's always UAC who can decide whether to use early or delayed offer. So in your case, when you make an outgoing call, it's your gateway who can choose between early and delayed offer, not your service provider. It's true vice-versa when gateway receives incoming call from service provider, your service provider decides whether to use early or delayed offer.
Coming back to your question and comments, we can't say it was early or delayed offer as you've not mentioned whether INVITE from gateway was sent with or without SDP. If it was with SDP, gateway is using early offer and if it was without SDP, gateway is using delayed offer.
The question is not much relevant because UAS has to respond as per request revived from UAC. If UAC has initiated call using delayed offer, UAS must have to support delayed offer else UAS should reject the call if doesn't support delayed offer.
Thanks for the information
Thanks for the information Vivek.
In our case call is disconnected from our end.
When the call gets connected and the destination receives the call then from our end "bye" is sent to the SIP provider.
Is this is related to SIP early offer or SIP early delay?
Calling number is on our end and the called number is on the SIP provider end.
22436
