SIP trunk firewall Traversal issue
Dear Experts,
I have configured SIP trunk with authentication. the authentication is username and password. I use CUBE to acheive this.
the call flow is like the following
phone ---> CCM 6.1 -----> H323 ----> CUBE -----> Firewall -----> Internet ------> SIP provider.
while I do troubleshooting, I found a message told me that the firewall traversal is not enabled.
I do stun configuration by using the following commands
voice sevice voip
stun
  stun flowdata agent-id 10
voice class stun-usage 1
stun usage firewall-traversal flowdata
after that, the firewall traversal message disappear from the logs. but the call is not working.
the sip provider has a STUN server, how we can use it ? and also what is the STUN ?
thanks in advance
Anas
Do you have captures from CUBE for a failed call?
Tapan
Re:SIP trunk firewall Traversal issue
It shows me a dead call, when I do.debug ccsip calls.
regards
Anas
Sent from Cisco Technical Support Android App
That reply is not helpful,
capture debug ccsip messages
And provide the logs.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Dears,
kindly find the attached logs
thanks in advance
Anas
Hi Guys,
can any one help me with this case ?
thanks in advance
regards
The version of the CUBE is 15.x?
Please rate all useful posts
Chrysostomos
""The Most Successful People Are Those Who Are Good At Plan B""
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Here's the issue:
Sent:
INVITE sip:009627XXXXXXX@sipgate.de:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.33.127:5060;branch=z9hG4bKF1147
Remote-Party-ID: <00494XXXXXXX1>;party=calling;screen=yes;privacy=off
To: <>009627XXXXXXX@sipgate.de>
Date: Sun, 07 Jul 2013 08:54:45 GMT
Call-ID: B47C60AE-E61911E2-8014F945-EAF1556@192.168.33.127
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 15705573-2133102877-100672513-3232243830
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1373187285
Contact: <00494XXXXXXX1>
Expires: 180
Allow-Events: telephone-event
Proxy-Authorization: Digest username="1430052e1",realm="sipgate.de",uri="sip:009627XXXXXXX@sipgate.de:5060",response="90b394921ae0523993f5f44fe1715f41",nonce="51d926d735a262f3a6904b27adba2bb98012f4a7",algorithm=md5
Content-Length: 0
Received:
SIP/2.0 403 Forbidden (check from field)
Via: SIP/2.0/UDP 192.168.33.127:5060;rport=49786;received=192.168.33.127;branch=z9hG4bKF1147
To: <>009627XXXXXXX@sipgate.de>;tag=6d6e7f8f352adddb20da2b196524dfa8.b769
CSeq: 102 INVITE
Content-Length: 0
Seems like the SIP Server does'n like the FROM header:
You can modify the FROM header with a SIP Profile:
voice class sip-profiles 1111
request ANY sip-header From modify "sip:(.*)@" "sip:[whatever they want to receive]@"
You may ask your Service Provider what they don't like on the INVITE, then you can modify it accordingly.
Some information if STUN:
http://www.voip-info.org/wiki/view/STUN
Jorge Armijo
964
