SIP Trunk from Telco company
Yazen Alaa
Dear
I have a Fiber coming from Telco or MOC , this fiber going to My Switch then going My Voice Router (with 2 Analog and one E1) as "SIP Trunk" with CUCM 8.6 .
My Questions are :
1) what I will configure in the intrface in  Switch that is going to Voice gateway ???
2)what I will configure in the intrface in  Voice router that is going to Switch  ???
Switch port interface -----> Voice port interface
3) ALL i need in CUCM , create SIP trunk and assign ip address of the Voice router or there are extra configuration ?? and i have to add this command " sip-ua " in voice gateway or i dont need it ???
4) do have good steps for my senario that is showing me how i will configure Fiber in my voice router as "sip trunk " or Sip trunk configuration ????
please this is urgent issue
thanks and regards
7 Replies 7
Hello Loay,
Please check the following link:
https://supportforums.cisco.com/docs/DOC-16447
The settings for the switch sholld be the same as for data provider.
HTH,
Alex
*Please rate helpful posts
Hi Alex
First of all thanks for ur reply , inactally i have confused regarding the role of the voice router and
but my senario is
Teleco or MOC Fiber------> Switch------->2900 Voice Router
                                                       Switch <--------CUCM 8.6
My Question is : What i Will configure in voice router and UBE ??
and My site is one only and there is no ather sites or branches , i think that the switch is here for routing as L3 is not for UBE ? i am right ?
and I got some setting from the Telco SIP ID and Username , for what this and where i will use it in the configuration ???
thanks and regards
Any Reply please
thanks
Are you looking for someone that configures you system? That would be the best option if you do not have Cisco Voice certification, or equivalent experience.
Hi Paolo
I think that your understood to my question was wrong however , i mean how to configure it to switch i mean UBE as i read and as i understand , however , i did every things but i have  faced some trouble in outgoing calls though SIP trunk
My Question again is
I have CUCM8.6 and Voice gateway that are connected through SIP Trunk to Teleco or MOC
it is giving me bust tone when i am tring call outside through sip trunk
Note  :-  E1 module and FXO module  are not used or not available , the call is  going from my voice router to Teleco Router to go outside
- DID ext : 22270800 to 899
why i cant call outside ???? how to solve it ???
i didnt create SIP trunk in CUCM , is it right becasue it is not nessary as i think ??? becasue i p2p gateway from side to telco side gateway ???
below the configuration and debug
the configuration is
card type e1 0 3
enable secret 4 gMj8cDXfU6CzFI9r1WoD5G6GTI5KwVY2O2lU2DSTP4c
no aaa new-model
network-clock-participate wic 3
no ipv6 cef
ip source-route
ip cef
isdn switch-type primary-net5
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
license udi pid CISCO2901/K9 sn FCZ1624711H
hw-module pvdm 0/0
redundancy
controller E1 0/3/0
pri-group timeslots 1-31
interface Embedded-Service-Engine0/0
no ip address
shutdown
description ## Connected to Fasttlco P2P ##
ip address 10.101.6.18 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
description ## Internal Network ##
ip address 10.10.1.5 255.255.255.0
duplex auto
speed auto
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
router rip
version 2
network 10.0.0.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/3/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp profile default
dial-peer voice 10 voip
destination-pattern 8..
session protocol sipv2
session target ipv4:10.200.200.50
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 11 pots
destination-pattern 9.T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/3/0:15
gatekeeper
shutdown
Debug is
Sep  1 20:20:04.630: //41/8017470F1100/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Sep  1 20:20:04.630: //41/8017470F1100/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3101F7A4, Tag=0x0, Call Id=41,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Sep  1 20:20:04.630: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep  1 20:20:04.630: :cc_free_feature_vsa freeing 2B3F72C8
Sep  1 20:20:04.630:  vsacount in free is 0
Sep  1 20:20:21.794: //-1/001669191200/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=22270840
   ----- ccCallInfo IE subfields -----
   cisco-ani=22270840
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=924950500
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Sep  1 20:20:21.794: //-1/001669191200/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3101F7A4, Call Info(
   Calling Number=22270840,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=924950500(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=42
Sep  1 20:20:21.794: //-1/001669191200/CCAPI/ccCheckClipClir:
   In: Calling Number=22270840(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=22270840(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Sep  1 20:20:21.794: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep  1 20:20:21.794: :cc_get_feature_vsa malloc success
Sep  1 20:20:21.794:  cc_get_feature_vsa count is 1
Sep  1 20:20:21.794: :FEATURE_VSA attributes are: feature_name:0,feature_time:725578448,feature_id:42
Sep  1 20:20:21.794: //42/001669191200/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=22270840(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=924950500(TON=Unknown, NPI=Unknown))
Sep  1 20:20:21.794: //42/001669191200/CCAPI/cc_process_call_setup_ind:
   Event=0x2B7C9F18
Sep  1 20:20:21.794: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 924950500
Sep  1 20:20:21.794: //42/001669191200/CCAPI/ccCallSetContext:
   Context=0x2ADBAE4C
   >>>>CCAPI handed cid 42 with tag 10 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep  1 20:20:21.794: //42/001669191200/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Sep  1 20:20:21.794: //42/001669191200/CCAPI/cc_api_get_transfer_info:
Sep  1 20:20:21.794: //42/001669191200/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3101F7A4, Tag=0x0, Call Id=42,
Sep  1 20:20:21.794: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep  1 20:20:21.794: :cc_free_feature_vsa freeing 2B3F72C8
thanks and regards
Hello Loay,
This disconnect is because of the tall fraud prevention.
You may try adding the following:
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
But it is good to fill with specific servers.
Please take a look at the following link about tall fraud prevention:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
HTH,
Alex
Hello Loay,
Did the previous step help you?
Best regards,
Alex
