SIP trunk incoming and outgoing calls issue
Hi Everyone,
We recently installad a SIP trunk and terminated on CUBE and CUCM but we have issues on incoming and outgoing calls, When someone dial in from outside he keeps listening the dailing ring even after we pick up the phone and at the end the callers time exipres and call gets disconnected.
For Dailing out, the dialed number rings and caller hear the dailing ring as well but if someone pick the phone it apprears that call is connected but no audio in it, dead air.
Our call flow is as
IP Phones => CUCM --->SIPTRUNK--->CUBE=>SIPTRUNK=>SP
I have attached the config for CUBE and debug ccsip messages output for both incoming and outgoing calls.
Please if some help in sorting out this issue, Thanks in Advance
Tasneem
1 ACCEPTED SOLUTION
Re: SIP trunk incoming and outgoing calls issue
could you please configure the below commands under 'voice service voip> sip' and check the behaviour?
  header-passing
  error-passthru
  asymmetric payload full
  midcall-signaling passthru
For the Inbound call from ITSP to CUCM, the CUCM sends 200 OK message to CUBE once the call is answered but the CUBE not passing the message to ITSP.
ITSP--->EO_SIP--->CUBE---EO_SIP--->CUCM
It seems the ITSP doing EO, so CUBE has to accept the call with one codec. configure inbound dial-peer from ITSP to CUBE with voice class codec containing only G711-Ulaw ((no early-offer forced required))
configure outbound dial-peer from CUBE to CUCM with same voice class codec above and also voice-class sip early-offer forced.
Similarly for outbound call, when the call is answered, CUBE receives 200 OK from ITSP and forwarded to CUCM. However CUCM doesn't respond with ACK
CUCM--->DO_SIP---->CUBE----DO_SIP---->ITSP
reconfigure inbound dialpeer from CUCM to CUBE with voice-class sip early-offer forced & voice class codec containing only G711-Ulaw, configure Outbound dial-peer from CUBE to ITSP with voice class codec containing only G711-Ulaw (no early-offer forced required).
let me know how it works after the changes please.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
  header-passing
  error-passthru
VIP Super Bronze
Inbound call>>>>
The reason you are experiencing this is that your CUBE is requesting PRACK and your provider is not responding to it..
Here we have your cube sending 180 ringing with "Require 100rel"..This was sent several times and your ITSP didnt respond probably because they do not support 100rel...(It is Huwaei after all, they do what they like)
Sent:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKkpw18wp35hfw2c23h51ww6a8aT19871
To: <8516666>;tag=256F3440-12C
Date: Thu, 16 Jan 2014 13:31:34 GMT
Call-ID: isbc6818c4kfhaa4ca1k5f8k1awsh52f1ccw@SoftX3000
CSeq: 1 INVITE
Require: 100rel
RSeq: 2507
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Remote-Party-ID: "TEST STC" <6666>;party=called;screen=yes;privacy=off
Contact: <6666>
Record-Route: <10.205.20.50:5060>
Server: Cisco-SIPGateway/IOS-15.2.4.M2
Content-Length: 0
AFter the CUBE didnt get any response, it then replied with Gateway Timeout...
Jan 16 13:31:54.550: //31880/5A4406E48184/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 504 Gateway Timeout
CSeq: 1 INVITE
Reason: Q.850;cause=102
Content-Length: 0
I suggest you disable this parameter..and test again
voice service voip
sip
rel1xx disable
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Outbound calls>>>>
CUCM is not responding with an ACK to the 200 OK as mentioned by Suresh...It is diffuclt to know why without looking at cucm traces...My first guess will be to check the region settins between your IP phones and the sip trunk...Your dial-peer to cucm is configured for G711, is  the region set to G711 or G729? if it is G729, do you have a xcoder?
The soultion that have been recommended  by Suresh have actually fixed the issue for both incoming and outgoing calls (thanks Suresh).
There is one more thing that I want to ask, this CUBE and all of our users ectensions are located on one geographic
locations and they break out to PSTN using SIP trunk but these extensions are managed by CUCM which is at a diffrent physical location but is reachable via VPN tunnel. The question that i want to ask , is it possible to configure that CUBE router for SRST as well so that when the VPN is down, the extensions can stay regestered to local CUBE router using SCCP and can talk to each ohter and can make PSTN calls over SIP trunk?
Good to know the issues are fixed.
Q13: Will SRST work on CUBE ?
A: Yes, SRST and CUBE can be co-located on the same router.
https://supportforums.cisco.com/docs/DOC-17964#Q13_Will_SRST_work_on_CUBE_
And you need SRST licensing for this.
1103
