SIP trunk incoming callto CUCM 7.1.5 - authorization problem.
Alexey Platov
Hi everybody.
Just run into the strange problem - if SIP trunk uses digest authentification then CUCM 7.1.5 behavesin a strange way.
Incoming call goes like that:
1st invite goes without digest credentials.
After "401 Unauthorized" goes ACK and INVITE with all needed credentials.
But after that again goes "401 Unauthorized" !
INVITE sip:200@10.1.1.221 SIP/2.0
               SIP/2.0 100 Trying
               SIP/2.0 401 Unauthorized  WWW-Authenticate: Digest realm="BOINC" ...
ACK sip:200@10.1.1.221 SIP/2.0
Authorization:  Digest username="cucm71",realm="BOINC",nonce=......
               SIP/2.0 100 Trying
I checked in the CUCM trace and found that digest user is not found
08/12/2011 13:02:05.005 CCM|ProcessSIPSecurity - can't find user cucm71 in the user table . Authorization fail.
But "cucm71" user is there.
If no digest authentification is used then, of course, incoming calls are OK.
With CUCM 6.1 I never have such problem.
Any clue?
Mitchell.Drage
Any chance you got this to work?
I am having a similar problem where I have the application user configured and it denies me:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 10.1.100.1:5060;branch=z9hG4bKF41929
To: ;tag=1504004667
Date: Sat, 21 Apr 2012 12:34:05 GMT
Call-ID: B2EB9BA8-8AE411E1-887EF97A-F80FE12A
CSeq: 5 REGISTER
Warning: 399 CUCMPUB "Unable to find device/user in database"
Content-Length: 0
sip-ua
credentials username SIPTEST password 7 ********* realm test
retry invite 2
retry register 10
timers connect 100
registrar ipv4:10.1.10.100 expires 3600
sip-server ipv4:10.1.10.100
host-registrar
Mitch
I did manage it.
It was my negligence - you should manage "Digest Credentials" for this Application User not onle name and password! And your SIP trunk should use name and digest credentials configured.
Yeah I noticed that yesterday from your image.
I think my problem is caused by something else despite following the cisco guide to the tee.
I'll start a new thread rather than continue from yours.
Good to hear you found a solution for your problem.
Go to the trunk and check the sip security profile associated with this trunk.
uncheck the enable Digest Authentication in Device trunk security profile in the cucm.
reset the profile.
