SIP trunk MTP and DTMF
Hi,Guys.
There is something i am missing and would be good if some one can help me understand it.
There is CUBE connected to ITSP and Internally with sip trunk to cucm 9,also there is UCCX.
Now incoming calls from the itsp to the uccx is traversing the sip trunk and what happens on the sip trunk is if i chose dtmf:no preference and MTP is not checked,then the digits the caller press is recognized and the menu works on uccx, but the caller from itsp side does not hear any thing (one way voice).
If i would check the mtp checkbox on the sip trunk and what ever the dmf method chose,the problem with one way resolved but the dtmf is not recognized.
Tried to configure Transcoder or mtp on the cube but this didn't fix the problem.
Any idea what could be the reason.
Thanks in advance.
Re: SIP trunk MTP and DTMF
Hi Ahmed.
Can you please attach your cube configuration an a debug ccsip messages?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi,Carlo
here is the configuration and debug ccsip messages:
voice service voip
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
  emptycapability
sip
  bind control source-interface FastEthernet0/1
  bind media source-interface FastEthernet0/1
  header-passing
  registrar server
  early-offer forced
  midcall-signaling passthru
Sent:
INVITE sip:796XXXXXXXX@85.94.32.248:5060 SIP/2.0
Via: SIP/2.0/UDP CubeIP:5060;branch=z9hG4bK9C07E89
Remote-Party-ID: "Ahmed" <2140>;party=calling;screen=yes;privacy=off
To: "796XXXXXXXX" <796XXXXXXXX>;tag=as60c34381
Date: Sat, 14 Sep 2013 12:34:57 GMT
Call-ID: 4748caba2706c94a7fb4ae77153df9c2@85.94.32.248:5060
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3405693557-477106659-2331803912-766779754
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 103 INVITE
Max-Forwards: 70
Timestamp: 1379162097
Contact: <74956385058>
Expires: 180
Allow-Events: kpml, telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 262
v=0
o=CiscoSystemsSIP-GW-UserAgent 7855 9390 IN IP4 CubeIP
s=SIP Call
c=IN IP4 CubeIP
t=0 0
m=audio 17514 RTP/AVP 0 101
c=IN IP4 CubeIP
a=inactive
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
2219843: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP CubeIP:5060;branch=z9hG4bK9C07E89;received=CubeIP;rport=50774
CSeq: 103 INVITE
Server: MCN-SS
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces
Contact: <796XXXXXXXX>
Content-Length: 0
2219844: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 INVITE
Server: MCN-SS
Supported: replaces
Content-Length: 236
v=0
o=MCN-MEDIA-GW 1998621654 1998621657 IN IP4 85.94.32.248
s=MCN-MEDIA-GW
c=IN IP4 85.94.32.248
t=0 0
m=audio 29310 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=inactive
2219845: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:796XXXXXXXX@85.94.32.248:5060 SIP/2.0
Via: SIP/2.0/UDP CubeIP:5060;branch=z9hG4bK9C08166A
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 0
2219846: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.99.41:5060;branch=z9hG4bK23b00d051920
From: <2401>;tag=327445~bb7f7ca1-8833-4f33-919e-af49f25af5bb-43548637
To: "796XXXXXXXX" <796XXXXXXXX>;tag=2CDD09EC-1481
Call-ID: CB01CFD5-1C7011E3-8B028108-2DB4216A@CubeIP
CSeq: 107 INVITE
Remote-Party-ID: "796XXXXXXXX" <796XXXXXXXX>;party=called;screen=no;privacy=off
Supported: replaces
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 205
v=0
o=CiscoSystemsSIP-GW-UserAgent 2486 801 IN IP4 CubeIP
s=SIP Call
c=IN IP4 CubeIP
t=0 0
m=audio 16418 RTP/AVP 0
c=IN IP4 CubeIP
a=inactive
a=ptime:20
2219847: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:796XXXXXXXX@CubeIP:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.99.41:5060;branch=z9hG4bK23b011f665793
Max-Forwards: 70
CSeq: 107 ACK
Allow-Events: presence
Content-Length: 0
2219848: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:796XXXXXXXX@CubeIP:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.99.41:5060;branch=z9hG4bK23b0229b69773
Supported: timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 3405693557-0477106659-2331803912-0766779754
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 108 INVITE
Max-Forwards: 70
Expires: 180
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "Ahmed" <2140>
Contact: <2401>
Content-Length: 0
2219849: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 108 INVITE
Content-Length: 0
2219850: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP CubeIP:5060;branch=z9hG4bK9C09869
Min-SE:  1800
CSeq: 104 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
2219851: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP CubeIP:5060;branch=z9hG4bK9C09869;received=CubeIP;rport=50774
CSeq: 104 INVITE
Server: MCN-SS
Supported: replaces
Content-Length: 0
2219852: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 104 INVITE
Server: MCN-SS
Supported: replaces
Content-Length: 236
v=0
o=MCN-MEDIA-GW 1998621654 1998621658 IN IP4 85.94.32.248
c2801#
s=MCN-MEDIA-GW
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
2219853: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 108 INVITE
Supported: replaces
Supported: sdp-anat
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 2486 802 IN IP4 CubeIP
s=SIP Call
c=IN IP4 CubeIP
t=0 0
m=audio 16418 RTP/AVP 0 101
c=IN IP4 CubeIP
a=fmtp:101 0-16
a=ptime:20
2219854: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.99.41:5060;branch=z9hG4bK23b037ff07da4
Max-Forwards: 70
CSeq: 108 ACK
Allow-Events: presence, kpml
Content-Length: 238
v=0
o=CiscoSystemsCCM-SIP 327445 5 IN IP4 192.168.99.41
s=SIP Call
c=IN IP4 172.21.16.93
b=TIAS:64000
b=AS:64
t=0 0
m=audio 24576 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
2219855: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP CubeIP:5060;branch=z9hG4bK9C0A8D
Max-Forwards: 70
CSeq: 104 ACK
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 7855 9391 IN IP4 CubeIP
s=SIP Call
c=IN IP4 CubeIP
t=0 0
c=IN IP4 CubeIP
a=fmtp:101 0-16
a=ptime:20
2219856: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:796XXXXXXXX@CubeIP:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.99.41:5060;branch=z9hG4bK23b04517d839c
Max-Forwards: 70
CSeq: 109 UPDATE
Contact: <2401>
Content-Length: 0
2219857: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
c2801#SIP/2.0 200 OK
CSeq: 109 UPDATE
Content-Length: 0
c2801#
c2801#
2219859: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:74956385058@CubeIP:5060 SIP/2.0
Via: SIP/2.0/UDP 85.94.32.248:5060;branch=z9hG4bK27ea9a51;rport
Max-Forwards: 70
To: <74956385058>;tag=2CDD0A28-15E0
CSeq: 103 BYE
User-Agent: MCN-SS
Reason: Q.850;cause=16
X-Asterisk-HangupCause: Normal Clearing
X-Asterisk-HangupCauseCode: 16
Content-Length: 0
2219860: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sat, 14 Sep 2013 12:35:24 GMT
CSeq: 103 BYE
Content-Length: 0
2219861: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:2401@192.168.99.41:5060 SIP/2.0
Via: SIP/2.0/UDP CubeIP:5060;branch=z9hG4bK9C0B237F
From: "796XXXXXXXX" <796XXXXXXXX>;tag=2CDD09EC-1481
To: <2401>;tag=327445~bb7f7ca1-8833-4f33-919e-af49f25af5bb-43548637
Max-Forwards: 70
Timestamp: 1379162124
CSeq: 109 BYE
Content-Length: 0
2219862: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 109 BYE
Content-Length: 0
2219863: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:CubeIP:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.99.41:5060;branch=z9hG4bK23b054e26b588
CSeq: 110 SUBSCRIBE
Event: kpml
Expires: 0
Contact: <192.168.99.41:5060>
Max-Forwards: 70
Content-Length: 0
2219864: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 110 SUBSCRIBE
Content-Length: 0
Contact:
Expires: 0
2219865: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:192.168.99.41:5060 SIP/2.0
Via: SIP/2.0/UDP CubeIP:5060;branch=z9hG4bK9C0C1CC2
CSeq: 110 NOTIFY
Max-Forwards: 70
Event: kpml
Subscription-State: terminated
Contact:
Cont
c2801#ent-Type: application/kpml-response+xml
Content-Length: 109
2219866: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 110 NOTIFY
Content-Length: 0
c2801#u
2219867: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:CubeIP:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.98.254:5060;branch=z9hG4bK306190bea23
To:
Date: Sat, 14 Sep 2013 12:35:29 GMT
Call-ID: 22274400-23415811-3062-fe62a8c0@192.168.98.254
User-Agent: Cisco-CUCM8.6
CSeq: 101 OPTIONS
Contact: <192.168.98.254:5060>
Max-Forwards: 0
Content-Length: 0
2219868: 15w3d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: ;tag=2CDE3810-E96
CSeq: 101 OPTIONS
Supported: 100rel,resource-priority,replaces,sdp-anat
Allow-Events: telephone-event
Accept: applic
c2801#u allation/sdp
Content-Length: 453
v=0
o=CiscoSystemsSIP-GW-UserAgent 6740 338 IN IP4 CubeIP
s=SIP Call
c=IN IP4 CubeIP
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
c=IN IP4 CubeIP
m=image 0 udptl t38
c=IN IP4 CubeIP
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxFillBitRemoval:0
a=T38FaxTranscodingMMR:0
a=T38FaxTranscodingJBIG:0
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:180
a=T38FaxUdpEC:t38UDPRedundancy
Thanks.
VIP Super Bronze
You forgot the dial-peers and sip-ua sections from your config.
Let's look at the SDP exchange so it's clear to you what CUBE is doing for both audio codec and DTMF relay:
! From ITSP offering SDP.
Received:
SIP/2.0 200 OK
CSeq: 104 INVITE
Server: MCN-SS
Supported: replaces
Content-Length: 236
v=0
s=MCN-MEDIA-GW
t=0 0
! The 0 means G.711 u-law and 101 means RFC2833.
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
! CUBE to CUCM delayed offer
Sent:
SIP/2.0 200 OK
CSeq: 108 INVITE
Supported: replaces
Supported: sdp-anat
Content-Length: 249
v=0
s=SIP Call
! This is the source IP of the RTP traffice from CUBE.
c=IN IP4 CubeIP
t=0 0
! Passing along the same capabilities.
c=IN IP4 CubeIP
a=fmtp:101 0-16
a=ptime:20
! CUCM accepting the SDP as-is.
Received:
Max-Forwards: 70
CSeq: 108 ACK
Content-Length: 238
v=0
s=SIP Call
! This is the IP address that CUCM is sourcing RTP from. What is this?
b=TIAS:64000
b=AS:64
t=0 0
a=ptime:20
a=fmtp:101 0-15
! CUBE accepting the SDP from the ITSP
Sent:
Max-Forwards: 70
CSeq: 104 ACK
Content-Length: 250
v=0
s=SIP Call
! CUBE replaces the 172.21.16.93 address with it's own (i.e. address-hiding).
c=IN IP4 CubeIP
t=0 0
c=IN IP4 CubeIP
a=fmtp:101 0-16
a=ptime:20
This means that CUCM will not enforce a specific DTMF relay method (i.e. it will allow either RFC2833 or RFC4730) and that it only invokes an MTP if required. Since CCX doesn't support RFC2833 my guess is that 172.21.16.93 is a media resource (MTP or transcoder) that is doing DTMF interop to SCCP OOB. If you have a one-way audio problem in thie scenario, then the RTP traffic is likely getting lost between CCX and CUBE. This is typically a routing problem. Can each hop route to the previous/next hop?
Ok, so now you're forcing CUCM to grab an MTP 100% of the time. In reality since CUCM needed one anyways for RFC2833 to SCCP OOB DTMF interop, you haven't gained anything here. The downside is that you're now consuming an MTP for *every* call, even if it doesn't need one. Now that you know how to read the SDP exchange, what is different in this scenario? Is the CUCM-provided C= line different? If yes, what does that address belong to?
You neglected to add your dial-peers but typically setting the dtmf-relay command to include both RFC2833 and KPML avoids this problem. CUBE includes both in its SDP offer, CUCM realizes that CCX doesn't support in-band DTMF methods and asks for KPML in it's response, and CUBE natively interworks between RFC2833 to the provider and KPML to CUCM. CUCM in turn converts the KPML events into CTI QBE events to the CCX CTI Ports.
Please remember to rate helpful responses and identify helpful or correct answers.
Hi,Jonathan.
Thank you for your time and explanation.
IP addresses :
Cube IP:this is our side public ip address facing the provider
192.168.99.41or 40:CUCM ip address.
172.16.21.X:this is an EZVPN pool (so the address was used by CIPC instead of voice vlan 99.0/24 cause i was using vpn).
I read the srnd part of MTP and i understand what you was explaning about uccx not supporting nte or more specific the cti ports.
But what is the solution ?I don't think this a routing issue cause the dialpeers are correct.
Take a look to the missing part of the configuration and advice please:
ip address CUBE IP 255.255.255.248
sccp local FastEthernet0/1
sccp ccm 192.168.99.40 identifier 2 priority 2 version 7.0
sccp ccm 192.168.99.41 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register MEDIA_T_P
dspfarm profile 1 mtp
codec g711ulaw
maximum sessions hardware 5
associate application SCCP
dial-peer voice 2000 voip
destination-pattern 2...
voice-class codec 1
session protocol sipv2
session target ipv4:192.168.99.41
dtmf-relay rtp-nte sip-kpml sip-notify h245-signal h245-alphanumeric
no vad
dial-peer voice 2001 voip
preference 1
voice-class codec 1
session target ipv4:192.168.99.40
no vad
dial-peer voice 10100 voip
tone ringback alert-no-PI
description MCN SIP Incoming
translation-profile incoming MCN
destination-pattern 74956385058
session target ipv4:85.94.32.248------------Provider's ip address
session transport udp
incoming called-number 74956385058
codec g711ulaw
Also from your explanation i feel that i am reading the sip debug wrong, for example:
Received:
OR
Received:
SIP/2.0 200 OK
How do you read it ?
Would you read it like this :200 ok is recived by itsp from the cube !
OR
Sent:
SIP/2.0 200 OK
I would read it like this :SIP 200 ok is sent from 192.168.99.41 to 85.94.32.248 which is the itsp .Correct me please if i am wrong!
Also what about this :
8000 ? is it trying to use g729 or negotiate g729 with provider.I know that phones use g729 by default.
Thank you so much.
VIP Super Bronze
So the SIP logs you provided aren't even from the call scenario you described?! You stated you are getting one-way audio to a CCX CTI Port yet this address is for CIPC? If correct you need to post logs that correspond to the problem you are reporting!
That would mean that SIP traffic is flowing directly from CUCM to the ITSP, which it isn't. Look at the Call-ID headers; the CUCM-side and ITSP-side SIP dialogs will have different values since CUBE is acting as a B2BUA. Generally speaking, a delayed offer dialog it goes like this:
INVITE
100 TRYING
180 RINGING
200 OK <- SDP Offer
ACK <- SDP Answer
8000 samples per second. The a= lines are merely defining the characteristics of the capabilities offered in the m= line. Read RFC4566 for additional detail.
PS- All you need is RFC2833 and KPML, not every option under the sun.
Of course i was posting the debug from this scenario.
I was calling from my mobile phone to the company number,translation pattern send the call to uccx,there was an option in the menu of uccx to dial by extension.So i called my CIPC to test the call.
I understand that as soon as i answered the call from my CIPC ,the RTP stream goes between my CIPC and my mobile phone and the cti port get released.
I found out that this problem not related so much to uccx.If i didn't check the mtp on the sip trunk .All incoming calls have one way voice.I hear but the PSTN caller does not hear me.
With MTP checked on the sip trunk.No one way voice,and dtmf digits are recognized if i call from inside the company to outside (fror example calling to bank with menu options ).
But the problem is dtmf is not regonized from the pstn side to us (uccx).
(8000 samples per second. The a= lines are merely defining the characteristics of the capabilities offered in the m= line. Read RFC4566 for additional detail.)
Thanks for expalining this part,i thought this is g729,now it's clear.I need to understand more the debug ccsip,i am reading about it.
(PS- All you need is RFC2833 and KPML, not every option under the sun.
dtmf-relay rtp-nte sip-kpml)
I know this well,but any way this does not matter cause the dialpeer will negotiate them in the order listed.
This dtmf under the dial peers should be the solution for this problem ,but it's not solving this.
Appericiate your time and help,but still don't know what is the solution?
1095
