Community Member
SIP Trunk on CME won't go to CUE
I've a CME router running 12.4(11)T with a SIP trunk to an ITSP.  All works fine except an inbound won't go to the CUE for voicemail.  Afte some investigation I found I need to disable the temporarily moved SIP messages with the "no supplementary-service SIP temporarily-moved" but it seems I don't have that command.
Under voice service voip, when I look at the command options for supplementary-service, i don't have a SIP option.  Is there something else I have to enable to give me this option??  Maybe it's broken in this IOS version although if it were a bug I'd still expect the command to be there.
THanks,
Neil
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: SIP Trunk on CME won't go to CUE
To send away the doubt, update IOS.
Community Member
thanks, i really didn't want to have to resort to that because I'm doing it remotely.  However, I bit the bullet and I now have the command and my CUE issue is resolved.
Neil
You are welcome, please remember to rate useful posts clicking on the stars below.
Community Member
I've given you a bit of a pasting on the other topic - I didn't like your comment  .  In this case, your 100% right
I've replied you there. Thank you for the nice rating and good luck!
211
