Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
SIP Trunk on CUCM 8.6.2
I'm trying to stablish a trunk connection from CUCM 8.6.2 Cluster to a Third party device for cloud based contact centre.
the client proivded their info and has asked me to configure media IP address on SIP trunk as well. But I can not find any option for that.
Can someone please advise?
1 ACCEPTED SOLUTION
Re: SIP Trunk on CUCM 8.6.2
Hi Kami
Are you able to ping your ISP and vice versa? Check in you firewall if there any RTP traffic going in both directions.
Also confirm if your MTP/XCODE are registered
Cheers
Bruno Rangel
Please remember to rate helpful  responses using the stars bellow and identify helpful or correct answers .
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
Hi kamin,
Are you using CUBE?
With help of CUBE you can bind your media IP address by two ways:
1). Globally
voice serice voip
sip
bind media source interface interface-id
exit
2). At dial-peer level
dial-peer voice XXXX voip
session target ipv4:XXX.XXX.XXX.XXX
session protocol sipv2
voice-class sip
exit
Nishant Savalia
Regards, Nishant Savalia
Bronze
Adding to what Nishant said, if you're not using CUBE for a 3rd party SIP trunk to CUCM, you should.  CUBE as your SIP edge in the environment offers you a multitude of options for directing traffic that CUCM doesn't handle natively, on top of the major benefits around security.
I've configured a 2921 as a cube for SIP trunk edge.
now I can recieve call but we dont have 2way audio and cant here eachother. They still asking me to configure media IP's in my side.
Media IP's are different from sip trnk termination IP.
Called number from third party is +19992430401 which will be translated to 960 and will be sent to CUCM (10.125.98.243)
Caonfiguration attached.
Bronze
Can you provide the messaging for a test call with the failed media?
debug ccsip messages
Reproduce the failed call, and output the log as an attachment.  I'm betting the CUBE is sending
Since your CUBE is behind a NAT, that NAT needs to be aware of SIP and needs to modify the SDP in order for media to work properly.  Media addresses in the SDP would use the CUBE's IP by default, and since you're not modifying any of the SDP/headers in the config, they are being instructed to send media to 10.125.32.107.  Unless you have a dedicated private link to that carrier, that won't work.  I doubted it was a dedicated link since your router is private IP but the carrier is public IP.
10.125.32.107 is cube private IP which is translated to a public IP oin Firewall. The third party has defined this public IP as SIP termination point in their side.
Trying to place a trst call and send you the log as well.
Thanks.
SIP log attached
Bronze
So you said there's a firewall between the carrier and your CUBE.  Is that firewall set up to transform SIP messaging traffic?  If not, that's your issue.  SIP media is not handled at layer 3, it's handled at a higher layer.  Many firewall vendors support "SIP transformation" as part of their NAT enablement.  This transformation would be want turns your CUBE's internal IP into 118.127.70.123 as part of the negotiation/INVITE process.  The carrier is asking you for media IP's because they are probably seeing your INVITE packets coming to them with 10.125.32.107 (unreachable to them) instead of 118.127.70.123 (I'm assuming this is the IP that is NAT'd to your CUBE).
I also see in your log that the call flow isn't indicative of traffic flowing properly (again, that NAT).
Here's what I see
  1. Inbound INVITE from them
  2. You sent TRYING
  3. You send RINGING
  4. They send another INVITE (you'd probably see this if they didn't get the reply TRYING or a 200 OK from you)
  5. Seems to keep looping 2-4 from there, with your device retrying the RINGING, and their device retrying the INVITE
When you use the bind statement to tie your signaling and media traffic to teh port channel's IP address, that firewall needs to be intelligent enough to translate that IP in the SDP message your router responds to their INVITE with, from internal IP to extenal IP.  You're getting the initial INVITE because that firewall is probably configured as a dumb layer 3 NAT, and it's taking the inbound traffic and handing it to the CUBE.  SIP's intelligence isn't at layer 3, so that firewall needs to do a bit more than simple NAT.
We had the same issues when initially setting up this exact environment, albeit with a different provider than you.  That firewall supported the SIP transformations, so once they were enabled, we were good to go.
I've enbaled sip transformation on firewall but still have the same issue.
Caller give me a call . ican hear the ring and see the caller ID. but caller says the call rejects and he can see the phone is ringing. but in my side the phone rings out.
Hi Kamin,
Please ask your service provider that whether they are receiving 100 trying / 180 ringing messgae in reponse to the INVITE message they sent.
Is this happening with outgoing call as well? If yes, then please share logs for outgoing call as well.
Also do share your connectivity topology i.e. how you and ISP are connected to and from CUBE?
  • ISP connects to which IP address?
  • CUBE is connected to which IP address for connectivity with ISP?
Nishant Savalia
Hi Kamin,
You set the command no IP address trusted list in router?
Bruno
no,
I trusted sip trunk termination ip.
please refer to configuration attached to this discussion.
Sorry, the commando that I used was no IP address trusted authentication.
Below is the full configuration:
sh    term le 0
Voice_Gateway#sh run
Building configuration...
Current configuration : 9753 bytes
! Last configuration change at 11:13:11 BR Wed Feb 12 2014
! NVRAM config last updated at 13:10:33 BR Wed Feb 12 2014
version 15.2
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname Voice_Gateway
boot-start-marker
boot config flash0:startup_config_1
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging buffered 10000000
no logging console
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
enable password 7 13061E010803
no aaa new-model
clock timezone BR -2 0
ip cef
ip traffic-export profile TAC mode capture
  bidirectional
ip dhcp relay information option
ip dhcp excluded-address 192.168.12.1
ip dhcp excluded-address 192.168.13.1
ip dhcp excluded-address 192.168.15.1 192.168.15.10
ip dhcp excluded-address 192.168.15.250 192.168.15.254
ip dhcp pool VOICE_SCOPE
network 192.168.12.0 255.255.255.0
default-router 192.168.12.1
option 150 ip 192.168.12.1
lease infinite
ip dhcp pool Dados
network 192.168.13.0 255.255.255.0
default-router 192.168.13.1
ip dhcp pool VOICE
network 192.168.15.0 255.255.255.0
default-router 192.168.15.1
option 150 ip 192.168.15.1
ip dhcp pool voz
ip domain name cisco.com
no ipv6 cef
voice-card 0
dspfarm
dsp services dspfarm
voice call carrier capacity active
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service sip moved-temporarily
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  bind control source-interface GigabitEthernet0/0.15
  bind media source-interface GigabitEthernet0/0.15
  registrar server expires max 600 min 60
  no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class codec 2
codec preference 2 g729r8
voice class h323 1
  call start slow
voice register global
mode cme
source-address 192.168.15.1 port 5060
max-dn 30
max-pool 30
load 9971 sip9971.9-4-1-9.loads
load 8941 sip8961.9-2-2SR1-9.loads
authenticate register
authenticate realm cisco.com
timezone 17
dialplan-pattern 1 3... extension-length 4
dialplan-pattern 2 1... extension-length 4
dialplan-pattern 3 2... extension-length 4
tftp-path flash:
create profile sync 0351135690512337
camera
video
voice register dn  1
number 5501
allow watch
name teste
label teste
voice register dn  2
number 2020
allow watch
name Show Room
label Show Room
voice register dn  3
number 2070
allow watch
name Show Room
label Show Room
voice register dn  5
number 3001
allow watch
name SIP
label SIP
voice register dialplan 1
type 7940-7960-others
pattern 1 3...
pattern 2 1...
pattern 3 2...
voice register pool  1
id mac 189C.5DB6.659D
type 9971
number 1 dn 1
dialplan 1
dtmf-relay rtp-nte
username 123456 password 123456
codec g711ulaw
no vad
voice register pool  2
id mac DCA5.F487.5ACC
type 8961
number 1 dn 2
username 2020 password 12345
codec g711ulaw
voice register pool  3
id mac 0004.F2BE.9054
number 1 dn 3
username 2070 password 2070
voice register pool  5
id mac 0000.0000.0000
number 1 dn 5
dtmf-relay rtp-nte
username 3001 password 12345
codec g711ulaw
no vad
license udi pid CISCO2901/K9 sn FTX173285AK
hw-module pvdm 0/0
hw-module pvdm 0/1
username admin privilege 15 secret 4 eaOP83n/Avy2EAs2tg7JbhLCX5T8h39E3GwBeTDW5sY
username cisco password 7 094F471A1A0A
username 2020 password 7 04095B545F
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
no ip address
duplex auto
speed auto
encapsulation dot1Q 1 native
ip address 192.168.1.2 255.255.255.0
interface GigabitEthernet0/0.12
encapsulation dot1Q 12
ip address 192.168.12.1 255.255.255.0
encapsulation dot1Q 15
ip address 192.168.15.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.15.1
interface GigabitEthernet0/1
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1.18
ip address 192.168.18.2 255.255.255.0
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip address 192.168.13.1 255.255.255.0
ip helper-address 192.168.13.1
ip default-gateway 192.168.15.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip access-list extended IP_CALLS
permit ip host 192.168.12.1 host 192.168.1.5
tftp-server flash:cmterm-894x-sccp.9-2-2-0.cop.sgn
tftp-server flash:BOOT894x.0-0-0-9.bin.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin1.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin2.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin3.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin4.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin5.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin6.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin7.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin8.sgn
tftp-server flash:SCCP894x.9-2-2-0.loads
tftp-server flash:cmterm-8961.9-2-2SR1-9.cop.sgn
tftp-server flash:dkern8961.100609R2-9-2-2SR1-9.sebn
tftp-server flash:kern8961.9-2-2SR1-9.sebn
tftp-server flash:rootfs8961.9-2-2SR1-9.sebn
tftp-server flash:sboot8961.031610R1-9-2-2SR1-9.sebn
tftp-server flash:sip8961.9-2-2SR1-9.loads
tftp-server flash:skern8961.022809R2-9-2-2SR1-9.sebn
tftp-server flash:dkern9971.100609R2-9-4-1-9.sebn alias dkern9971.100609R2-9-4-1-9.sebn
tftp-server flash:kern9971.9-4-1-9.sebn alias kern9971.9-4-1-9.sebn
tftp-server flash:rootfs9971.9-4-1-9.sebn alias rootfs9971.9-4-1-9.sebn
tftp-server flash:sboot9971.031610R1-9-4-1-9.sebn alias sboot9971.031610R1-9-4-1-9.sebn
tftp-server flash:sip9971.9-4-1-9.loads alias sip9971.9-4-1-9.loads
tftp-server flash:skern9971.022809R2-9-4-1-9.sebn alias skern9971.022809R2-9-4-1-9.sebn
control-plane
mgcp profile default
sccp local GigabitEthernet0/0.15
sccp ccm 192.168.15.20 identifier 1 version 7.0
sccp ccm group 1
bind interface GigabitEthernet0/0.15
associate ccm 1 priority 1
associate profile 1 register Trans_CUCM
dspfarm profile 1 transcode universal
codec ilbc
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 10
associate application SCCP
dial-peer voice 10 voip
description ************ Calls to Avaya - SIP
shutdown
destination-pattern 10..
session target ipv4:192.168.1.5
session transport tcp
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 11 voip
description ************ Calls to Avaya - H323
destination-pattern 1054
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 50 voip
description ************ Calls to SIP
destination-pattern 2...
session target ipv4:192.168.15.1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1 voip
description ************ Calls to Escritorio BH
destination-pattern 200.
session target ipv4:192.168.33.33
voice-class codec 1
dial-peer voice 100 voip
description ************ TESTE SIP
destination-pattern 2020
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 102 voip
destination-pattern 3001
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 101 voip
destination-pattern 1...
session target ipv4:192.168.15.10
voice-class codec 1
dtmf-relay rtp-nte sip-notify
dial-peer voice 1001 voip
incoming called-number .
voice-class codec 1
sip-ua
retry invite 5
retry response 10
registrar ipv4:192.168.15.10 expires 3600
sip-server ipv4:192.168.15.10
gatekeeper
shutdown
telephony-service
em keep-history
max-ephones 30
max-dn 30
ip source-address 192.168.15.1 port 2000
service local-directory authenticate
service dss
system message Laboratorio CME
load 8941 SCCP894x.9-2-2-0
time-zone 17
time-format 24
date-format dd-mm-yy
max-conferences 12 gain -6
web admin system name bruno password bruno
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Feb 11 2014 14:08:17
ephone-dn  1
number 3000
label Bruno Falco
name Bruno Falco
ephone-dn  2
number 8880
label karina
name karina
ephone-dn  3
number 3001
label Noronha
name Noronha
ephone  1
mac-address AAAA.AAAA.AAAA
type CIPC
button  1:1 2:2
ephone  2
mac-address BBBB.BBBB.BBBB
type CIPC
button  1:2
ephone  3
mac-address E411.5B53.FFB1
type CIPC
button  1:3
ephone  5
line con 0
password 7 01100F175804
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 104D000A0618
login
transport input all
line vty 5 15
login local
transport input all
scheduler allocate 20000 1000
ntp master 1
ntp server 192.168.1.40
ntp server 192.168.15.1
ntp server 192.168.1.2
end
Hi Kami
Cheers
Bruno Rangel
1227
