Community Member
Sip trunk problem on cme 3825 but works on AsteriksWin32 server
I need help.
Im trying to configure a sip trunk on my cme 3825, but i cant get works.
i made a call and the other side ring but thats all. just noise in both sides.
i debug the ccsip messages and i saw that i sent invite messages, but never recived
ack or any message from the sip-server.
The weird thing is that the trunk is tested by the local provider with
a asteriksWin32 Pbx and the calls incoming and recive are just fine!!!
so pls, what wrong with mi router !!!
the provider told the parameters of the sip trunk
- its sip-server A.B.C.D
- its a ip athenticate based (172.22.24.46)
- the sip server recive a 53197010 as calling number.
this is mi configuration:
Router#show run
Building configuration...
voice service voip
sip
voice class codec 1
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g723ar63
codec preference 4 g711ulaw
codec preference 5 g711alaw
voice translation-rule 1
rule 1 /^.*/ /53197010/
voice translation-profile out5
translate calling 1
interface GigabitEthernet0/0
description TRONCAL SIP
ip address 172.22.24.46 255.255.255.252
interface GigabitEthernet0/1
description LAN_SOFTPHONE
ip address 172.25.51.252 255.255.254.0
ip route 0.0.0.0 0.0.0.0 172.22.24.45
dial-peer voice 11 voip
description outgoing sip calls
translation-profile outgoing out5
service session
destination-pattern T
voice-class codec 1
session protocol sipv2
session target ipv4:A.B.C.D
dtmf-relay rtp-nte
clid network-number 53197010
no vad
dial-peer voice 200000 voip
description incoming sip calls
voice-class codec 1
incoming called-number T
dtmf-relay sip-notify rtp-nte
sip-ua
registrar ipv4:A.B.C.D expires 3600
----------------------------------------the debug ccsip messages
mi debug cccsip show that i send sip invite packets but no response from the server openser.
Sent:
INVITE sip:3592867@A.B.C.D:5060 SIP/2.0
Via: SIP/2.0/UDP 172.22.24.46:5060;branch=z9hG4bK1B37F
Remote-Party-ID: <sip:53197010@172.22.24.46>;party=calling;screen=yes;privacy=of
f
To: <sip:3592867@A.B.C.D>
Date: Wed, 07 Oct 2009 22:12:26 GMT
Call-ID: 419E2136-B2C511DE-80E99823-EC0DC785@172.22.24.46
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 970522294-2999259614-2162464803-3960326021
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF
Y, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1254953546
Contact: <sip:53197010@172.22.24.46:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 245
finally shows...
*Oct 7 22:12:58.199: //74/39D8FEB680E4/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x65EC0340
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 53197010
Called Number : 3592867
Source IP Address (Sig ): 172.22.24.46
Destn SIP Req Addr:Port : A.B.C.D:5060
Destn SIP Resp Addr:Port : A.B.C.D:5060
Destination Name : A.B.C.D
*Oct 7 22:12:58.199: //74/39D8FEB680E4/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 172.22.24.46
Source IP Port (Media): 16446
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 102
Disconnect Cause (SIP) : 200
1 REPLY
Re: Sip trunk problem on cme 3825 but works on AsteriksWin32 ser
Try:
voice service voip
allow-connections sip to sip
126
