SIP trunk signalling disabled issue
I'm trying to configure sip trunk on cube cisco AS5350 with ITSP. But when i see the below ouptut it gives signalling disabled. The call are also not going through. What can be the reason for this issue.
Below is output of
sh sip-ua status
SIP User Agent Status
SIP User Agent for UDP : ENABLED
SIP User Agent for TCP : ENABLED
SIP User Agent for TLS over TCP : ENABLED
SIP User Agent bind status(signaling): DISABLED
SIP User Agent bind status(media): ENABLED 1.1.1.1
SIP early-media for 180 responses with SDP: ENABLED
SIP max-forwards : 70
SIP DNS SRV version: 2 (rfc 2782)
NAT Settings for the SIP-UA
Role in SDP: NONE
Check media source packets: DISABLED
Maximum duration for a telephone-event in NOTIFYs: 2000 ms
SIP support for ISDN SUSPEND/RESUME: ENABLED
Redirection (3xx) message handling: ENABLED
Reason Header will override Response/Request Codes: DISABLED
SDP application configuration:
 Version line (v=) required
 Owner line (o=) required
 Timespec line (t=) required
 Media supported: audio image
 Network types supported: IN
 Address types supported: IP4
 Transport types supported: RTP/AVP udptl
1 REPLY
Hello, You may need to bind
You may need to bind the correct interfaces to send/receive the SIP signalling from ITSP & CUCM.
Please refer this blog on how the binding works.
https://supportforums.cisco.com/blog/154506
It gives the idea on how to configure CUBE with correct dial-peers & bindings.
After all this done, if the calls are still failing, please provide the running config of the CUBE with below debugs and include the calling/called numebrs.
- debug ccsip mess
- debug voice ccapi inout.
//Suresh
Please rate all the useful posts
//Suresh Please rate all the useful posts.
56
