SIP Trunk Specifics
Hey All,
I'm newer to the SIP world with Cisco and have a few basic questions I am having a hard time finding answers for, so please bear with me if the questions have obvious answers that I may have missed.
A little back ground.
We are integrating a Cisco CUCM release 7.0 to an internal IVR using SIP Trunks.
The questions are:
Is there licensing specifically for SIP Trunks?
How many simultaneous calls can be pushed through a single SIP Trunk?
How do I calculate the required amount of bandwidth needed on the LAN based on the numbers of calls across the SIP Trunk or Trunks?
Thanx...Frank
2 ACCEPTED SOLUTIONS
Re: SIP Trunk Specifics
Hey,
Is there licensing specifically for SIP Trunks? - no special license needed.
How many simultaneous calls can be pushed through a single SIP Trunk? - there is no limit except your bandwidth
How do I calculate the required amount of bandwidth needed on the LAN based on the numbers of calls across the SIP Trunk or Trunks? - based on codecs you use, check this link for full information: http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080094ae2.shtml
No licensing required, also no maximum number of calls (depends on BW you have or calls the telco will allow).
For the BW use this tool:
Voice Codec Bandwidth Calculator
http://tools.cisco.com/Support/VBC/do/CodecCalc1.do
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hey,
java
java
225
