SIP Trunk test plan
Please can someone tell what's the procedure follow to test the SIP Trunk deployed with the provider.
Thanks.
SIP Trunk test plan
In a simple way, Call a number with which matches full route pattern and have only the sip trunk in the "Available devices" in the route group. so you are forcing the call to take this specific trunk and see if the call completes.
Hope this helps.
-Abdul
Please rate helpful posts!!!
SIP Trunk test plan
thak you  Abdul Sattar but what i am looking for is the full procedure from end to end
SIP Trunk test plan
hi,
use dialed number analyser and do the test for call flow.
regards,
baskaran
Blue
SIP Trunk test plan
Below link shows best practice of SIP trunk for PSTn access. See if this helps in creating your test plan based on best practice.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps5640/white_paper_c11-620461.html
Below link shows you tested configuration with tested service provider.
http://www.cisco.com/en/US/solutions/ns340/ns414/ns728/networking_solutions_products_genericcontent0900aecd805bd13d.html
Not sure how much this will help you, But refering above doc will give you idea what to expect in SIP PSTN access.
regards
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
SIP Trunk test plan
Thank you patel it is really helpful
2072
