Community Member
SIP trunk to CallManager Express - No Ring Back
Hi there,
I've connected the CallManager Express through a SIP trunk to a SIP provider. I have the following situation:
Sip Telephone Number -> SIP Provider -> SIP TRUNK -> CallManager Express -> IP Phone
When I call the SIP telephone number (either from PSTN or chell phone), then there is no Ring Back.
I hope someone can help me to sort out this issue.
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: SIP trunk to CallManager Express - No Ring Back
Try
progress_ind setup enable 3
under the incoming voip DP.
Try
progress_ind is for h.323 only (at least that's what they say in the command ref) ;)
This was originally written for H323, but I've seen it applied for SIP as well.
-nick
Please post 'debug ccsip message'
-nick
VIP Red
Yama,
once you have produced the debug innformation, after the INVITE from your SIP provider as a result of the incoming call attempt, your gw shoudl send a 180 "RINGING" message back to your SIP provider, see if that is actually happening
RUBY! RUBY! RUBY!
Please remember to rate useful posts, by clicking on the stars below.
612
