SIP trunk to CUCM gateway
Do SIP trunks have to terminate to the CUCM?  Or can the terminate to a gateway on the CUCM?  Everything I have read indicates it terminates to the CUCM directly, and I have a couple working like that, but I would like to have it terminate to a router remotely if possible.
Hello Clark,
Yes you can add a SIP trunk to Gateway couple of things needs to be done more on GW side like dial-peer, Binding, allowing connection
what's exactly your topology and purpose that you are going to used
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Hall of Fame Super Silver
Typically Ciso recommends SIP trunk (assuming PSTN trunk) connection to CUBE (voice GW router with CUBE licenses) rather than direct connection to CUCM for many reason, such as demarcation, security, authentication, header modification, etc.
HTH,
Chris
On the gateway router, I have a PRI connected at the present time.  I have another location with a CME - SIP PSTN connection.  When I went to setup 4 digit dialing between CUCM and CME, I configured the Trunk in the CUCM and had to connect the CME to the CUCM directly.  When I attempted to configure the CME to attach to the CUCM gateway router, I get fast busy "unknown number" on phone and when I debug "debug voice ccapi inout" it shows disconnect cause 1.
The site that is currently a CME, will eventually become a gateway on the CUCM.  Since the only way I could get the SIP trunk to work was to tie it directly to the CUCM, I thought it was just not possible.  So, how do I configure the router to recieve a SIP trunk for the CUCM?  I have read 4 different forum posts here that document how to create SIP trunk directly to the CUCM, but none that specify how to terminate it to the gateway router.
Hi Clark,
Ip-phone>>cucm>>sip-trunk>>cme>>ipphone.
This is your call-flow, do correct me if  i am wrong.
Now this is what you need to do:
On the CME:
voice service voip
allow h323 to h323
allow h323 to sip
allow sip to sip
allow sip to h323
Dial-peer voice 100 voip
sess protocol sipv2
destination-patter 4...$
session target ipv4:192.168.4.4>>>>Ip-address of the CUCM
codec g711ulaw
dtmf-relay sip-notify
no vad
This dial-peer would be for the incoming call from the CUCM:
Dial-peer voice 1 voip
sess protocol sipv2
incoming called-number .
On the CUCM SIP-trunk:
Make sure you have ip-address of the CME added in the destination address:
SIP Information
Destination
Destination Address
Destination Address Destination Address IPv6 Destination Port
Do rate the post accordingly.
Kevin
That is what I already have, and that works fine.  What I want to know is how do it create a call-flow as follows:
ip phone --> cme --> sip-trunk --> Gateway router --> cucm --> ip phone
This is because eventually, the cme will become a gateway router for the cucm, and the cme currently has sip trunk from the PSTN terminating to it at the remote site.  With cme, it is very easy to recieve a SIP trunk from the PSTN.  How do I get the PSTN sip trunk to route calls in to the gateway router (like a PRI), without directly terminating the PSTN sip trunk to the cucm?
Then this should work, Can you send me the output of the following debug:
debug voip ccapi inout
debug ccsip messages
do let me  know the calling and the called numbers withe range of number on the CUCM where you would want to route the calls to.
Kevin
Hi clark,
In your case you have to create two dial-peers on your CME (which is your gateway router).
  • 1st dial-peer to accept incoming call from PSTN SIP
  • 2nd dial-peer is pointing towards CUCM SIP Trunk
Nishant Savalia
Regards, Nishant Savalia
807
