Sip Trunk - to itsp
I can't seem to get a sip trunk working to my itsp, I did a debug ccsip all and below are the only debug messages I receive....Any ideas?
*Sep  6 18:35:06.559: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_register_cred_user: Sending msg type 2 to register process from parser for user 8592828662
*Sep  6 18:35:06.559: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_spi_register_process_e164_registration: CCSIP_REGISTER:: e164 number (8592828662)
*Sep  6 18:35:06.559: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/ccsip_register_search_e164_table: ****No entry found in E164 Table
*Sep  6 18:35:07.215: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_register_reset_dns_cache: CCSIP_REGISTER:: registrar 0 DNS resolved addr reset
*Sep  6 18:35:07.215: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_spi_register_update_e164_registrations: CCSIP_REGISTER:: e164 number (8592828662) event (1)
*Sep  6 18:35:07.215: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/ccsip_register_search_e164_table: ****No entry found in E164 Table
*Sep  6 18:35:07.215: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_spi_register_get_rcb: Getting New RCB [0x3D2E2BCC]
*Sep  6 18:35:07.215: //-1/xxxxxxxxxxxx/SIP/Info/critical/262144/ccsip_spi_outgoing_register: Process CCSIP_SPI_CONTROL not UP yet; send no Register msg
*Sep  6 18:35:07.215: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_register_delete_from_e164_table:
hostname CUBE
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.153-3.M.bin
boot-end-marker
aqm-register-fnf
logging buffered 51200 warnings
enable secret 5 $1$7iyg$DEfVU0ptjcJ/QGbIWpbYc0
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
ip domain lookup source-interface GigabitEthernet0/0
ip domain name csf.csf.com
ip name-server 8.8.8.8
ip name-server 4.2.2.2
ip cef
no ipv6 cef
voice-card 0
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g726r16
codec preference 4 g726r24
codec preference 5 g726r32
codec preference 6 g723r53
codec preference 7 g723ar53
codec preference 8 g723r63
codec preference 9 g723ar63
voice class codec 2
codec preference 1 g729br8
voice class h323 50
  h225 timeout tcp establish 2
  h225 timeout call-proceeding 2
  h225 timeout setup 2
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout ntf 500
  call start fast
license udi pid CISCO2921/K9 sn FTX1419AJN5
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
description Uplink to g1/17
ip address 172.31.2.175 255.255.255.224
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip http server
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 172.31.2.161
control-plane
sip-ua
credentials username 8392228662 password test realm 67.228.194.2
authentication username 8392228662 password test realm 67.228.194.2
no remote-party-id
retry invite 3
retry register 3
timers register 150
registrar ipv4:67.228.194.2 expires 200
sip-server ipv4:67.228.194.2
gatekeeper
shutdown
Re: Sip Trunk - to itsp
Have you tryed with credential number instead of credential username?
Try it and issue show sip-ua register status
Carlo
Please rate all helpful posts "The more you help the more you learn"
Sip Trunk - to itsp
Change to:
credentials number 8592828662 username 8592828662 password 7 065F5B221B1A0A1B07 realm 67.228.194.2
and received the following:
*Sep  6 19:38:49.991: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_register_cred_user: Sending msg type 2 to register process from parser for user 8592828662
*Sep  6 19:38:49.991: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_spi_register_process_e164_registration: CCSIP_REGISTER:: e164 number (8592828662)
*Sep  6 19:38:49.991: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/ccsip_register_search_e164_table: ****No entry found in E164 Table
*Sep  6 19:38:49.991: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_spi_register_get_rcb: Getting New RCB [0x41D67F98]
*Sep  6 19:38:49.991: //-1/xxxxxxxxxxxx/SIP/Info/critical/262144/ccsip_spi_outgoing_register: Process CCSIP_SPI_CONTROL not UP yet; send no Register msg
*Sep  6 19:38:49.991: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_register_delete_from_e164_table:
Invalid Entry for search key
*Sep  6 19:38:49.991: //-1/xxxxxxxxxxxx/SIP/Info/verbose/262144/ccsipGetCCBFromRCB: Retrived CCB pointer [0x0]
*Sep  6 19:38:49.991: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_spi_register_free_rcb: Freeing rcb [0x41D67F98]
Try this
credentials number 8592828662 username 8592828662 password 7 065F5B221B1A0A1B07 realm 67.228.194.2:5060/8592828662
Carlo
Hi,Did this ever get resolved
Did this ever get resolved? Could please share with me what you did? Thanks.
1080
