10-27-2010 01:27 PM - edited 03-16-2019 01:35 AM
I generally run CDR route group reports for my MGCP trunks for utilization, but when I try to report on the SIP trunk route groups, it comes back null. Is there a way in CDR analysis and reporting to run busy hour utilization reports for SIP Trunks? Thanks!
Solved! Go to Solution.
10-27-2010 01:39 PM
Unfortunately SIP trunks are not available for this reports.
I'm not sure if there is already an enhancement request on this, but if not, get in touch with your AM and ask him about submitting a PER.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
10-27-2010 01:39 PM
java
10-27-2010 01:41 PM
Thanks for the quick reply Java. That's what I figured when I couldn't find any documentation on it in the help files.
I will put in an enhancement request.
Brett
10-27-2010 02:32 PM
Does anyone have a good 3rd party tool to generate SIP trunk utilization reports? Thanks.
07-20-2011 12:39 PM
Has anyone seen any new information on historical SIP trunk utilization reporting in CUCM?
