Community Member
SIP trunk via g729
Hi Voice Team,
I have a SIP integration between Cisco CUCM and Siemens Hipath.
I have the environment working properly via g711, but I wuld like to work with g279 and it is not working...
My environment is:
CUCM ---- Router (MPLS) ---          MPLS              --- Vanguard ----- Siemens
In Summary, the calls via g711 is ok, but g729 is not working...
I did a new region with device pool with g729 and I´m using a phone to test with the new device pool...
Siemens IP: 10.201.1.28
CUCM IP: 172.16.8.240
DN: 3001 (Siemens)
DN: 5157 (Cisco)
The trace file was attached.
Thanks all.
Community Member
Re: SIP trunk via g729
What is your cucm version?
Jean,
your g729 call is not working because invite from siemens only advertising g711 codec in the invite message, also you dont have any tracscoder configure for it to work
to resolve it you have 2 options
# configure transcoder so that ....
      phone to transcoder : g729
      transcoder to sip trunk: g711
# configure on Siemens to advertise g729!!
thanks,
Vipul Jindal
Community Member
SIP trunk via g729
Thanks all.
The problem was in the Siemens PBX.
Community Member
We did trunk with g729a on Siemens PBX.
Thanks all.
511
