sip trunk, want to block an incoming number
hi,
running 2811 with cme 7.1
I want to block an incoming call from phone ex: 555-111-2222
here is my config but it,s not blocking the call, I'm calling from my cell phone the main number of my CME and the call is not getting blocked.
voice translation-rule 5000
rule 1 reject /5551112222/
voice translation-profile SPAM
translate calling 5000
dial-peer voice 100 voip
call-block translation-profile incoming SPAM
call-block disconnect-cause incoming user-busy
some debug,
41391=autoattendant
1112223333 = main did
5551112222 = my cell phone number
RTR#
Dec  5 2013 20:30:57.528 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=1112223333, Called Number=1112223333, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=1112223333
Dec  5 2013 20:30:57.528 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=1112223333, Expanded String=1112223333, Calling Number=1112223333T
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Dec  5 2013 20:30:57.528 CAN-QC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=20001 Is Matched
   Result=Success(0) after DP_MATCH_DEST
Dec  5 2013 20:30:57.528 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20001
Dec  5 2013 20:30:57.532 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=5551112222, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Match Rule=DP_MATCH_ANSWER; Calling Number=5551112222
Dec  5 2013 20:30:57.532 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Dec  5 2013 20:30:57.532 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=5551112222T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
Dec  5 2013 20:30:57.532 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=5551112222
   Result=-1
   Result=NO_MATCH(-1) After All Match Rules Attempt
Dec  5 2013 20:30:57.532 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec  5 2013 20:30:57.536 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec  5 2013 20:30:57.536 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec  5 2013 20:30:57.536 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec  5 2013 20:30:57.536 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
   Result=-1
Dec  5 2013 20:30:57.536 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec  5 2013 20:30:57.540 CAN-QC: //-1/E3FF0CD38085/DPM/dpAssociateIncomingPeerCore:
   Calling Number=5551112222, Called Number=1112223333, Voice-Interface=0x0,
   Match Rule=DP_MATCH_REQUEST_URI; URI=sip:1112223333@66.131.75.54:1024
Dec  5 2013 20:30:57.540 CAN-QC: //-1/E3FF0CD38085/DPM/dpMatchPeertype:
Dec  5 2013 20:30:57.540 CAN-QC: //-1/E3FF0CD38085/DPM/dpMatchCore:
   Result=-1
Dec  5 2013 20:30:57.540 CAN-QC: //-1/E3FF0CD38085/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_TO_URI; URI=sip:1112223333@66.131.75.54:1024
   Result=-1
   Match Rule=DP_MATCH_FROM_URI; URI=sip:5551112222@67.205.74.184
   Result=-1
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=1112223333
Dec  5 2013 20:30:57.540 CAN-QC: //-1/E3FF0CD38085/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1 Is Matched
   Result=Success(0); Incoming Dial-peer=3003 Is Matched
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=3003
Dec  5 2013 20:30:57.544 CAN-QC: //-1/E3FF0CD38085/DPM/dpAssociateIncomingPeerSPI:exit@6170
Dec  5 2013 20:30:57.560 CAN-QC: //-1/E3FF0CD38085/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=41391, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=41391
Dec  5 2013 20:30:57.560 CAN-QC: //-1/E3FF0CD38085/DPM/dpMatchCore:
   Dial String=41391, Expanded String=41391, Calling Number=
Dec  5 2013 20:30:57.560 CAN-QC: //-1/E3FF0CD38085/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=41391 Is Matched
Dec  5 2013 20:30:57.560 CAN-QC: //-1/E3FF0CD38085/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=41391
   Result=SUCCESS(0)
Dec  5 2013 20:30:57.560 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=41391, Called Number=41391, Peer Info Type=DIALPEER_INFO_SPEECH
Dec  5 2013 20:30:57.560 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=41391, Expanded String=41391, Calling Number=41391T
Dec  5 2013 20:30:57.560 CAN-QC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec  5 2013 20:30:57.560 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Dec  5 2013 20:30:57.564 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=41391, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=41391
Dec  5 2013 20:30:57.564 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec  5 2013 20:30:57.564 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=41391T
   Result=-1
Dec  5 2013 20:30:57.564 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=41391
Dec  5 2013 20:30:57.564 CAN-QC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=41391 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=41391
Dec  5 2013 20:30:57.564 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
   Result=-1
Dec  5 2013 20:30:57.568 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec  5 2013 20:30:57.568 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec  5 2013 20:30:57.568 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dec  5 2013 20:30:57.568 CAN-QC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec  5 2013 20:30:57.568 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Dec  5 2013 20:30:57.568 CAN-QC: //-1/E3FF0CD38085/DPM/dpMatchPeersCore:
Dec  5 2013 20:30:57.568 CAN-QC: //-1/E3FF0CD38085/DPM/dpMatchCore:
Dec  5 2013 20:30:57.568 CAN-QC: //-1/E3FF0CD38085/DPM/MatchNextPeer:
Dec  5 2013 20:30:57.572 CAN-QC: //-1/E3FF0CD38085/DPM/dpMatchPeersCore:
Dec  5 2013 20:30:57.572 CAN-QC: //-1/E3FF0CD38085/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Dec  5 2013 20:30:57.664 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=5551112222, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=5551112222
Dec  5 2013 20:30:57.664 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=5551112222, Expanded String=5551112222, Calling Number=
   Result=-1
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Dec  5 2013 20:30:57.664 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
Dec  5 2013 20:30:57.664 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec  5 2013 20:30:57.668 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec  5 2013 20:30:57.668 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec  5 2013 20:30:57.668 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Dec  5 2013 20:30:57.668 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec  5 2013 20:30:57.668 CAN-QC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec  5 2013 20:30:57.668 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec  5 2013 20:30:57.716 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Dec  5 2013 20:30:57.716 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec  5 2013 20:30:57.716 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
Dec  5 2013 20:30:57.716 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec  5 2013 20:30:57.720 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec  5 2013 20:30:57.720 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec  5 2013 20:30:57.720 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec  5 2013 20:30:57.720 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Dec  5 2013 20:30:57.720 CAN-QC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec  5 2013 20:30:57.720 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec  5 2013 20:30:57.724 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec  5 2013 20:30:57.724 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec  5 2013 20:30:57.724 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec  5 2013 20:30:57.724 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Dec  5 2013 20:30:57.728 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec  5 2013 20:30:57.728 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec  5 2013 20:30:57.728 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec  5 2013 20:30:57.728 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Dec  5 2013 20:30:57.728 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec  5 2013 20:31:03.168 CAN-QC: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId E3FF0CD35D4C11E38085CB79F091560D, Se        tupTime 20:30:57.548 CAN-QC Thu Dec 5 2013, PeerAddress 5551112222, PeerSubAddress , DisconnectCause 10  , DisconnectText norma        l call clearing (16), ConnectTime 20:30:57.728 CAN-QC Thu Dec 5 2013, DisconnectTime 20:31:03.168 CAN-QC Thu Dec 5 2013, CallOr        igin 2, ChargedUnits 0, InfoType 2, TransmitPackets 272, TransmitBytes 43520, ReceivePackets 254, ReceiveBytes 40640
Dec  5 2013 20:31:03.168 CAN-QC: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:12/05/2013 20:30:57.548,cgn:5551112222,cdn:51        43603496,frs:0,fid:35,fcid:E3FF0CD35D4C11E38085CB79F091560D,legID:56,bguid:E3FF0CD35D4C11E38085CB79F091560D
Dec  5 2013 20:31:03.176 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
Dec  5 2013 20:31:03.176 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
Dec  5 2013 20:31:03.180 CAN-QC: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId E3FF0CD35D4C11E38085CB79F091560D, Se        tupTime 20:30:57.580 CAN-QC Thu Dec 5 2013, PeerAddress 41391, PeerSubAddress , DisconnectCause 10  , DisconnectText normal cal        l clearing (16), ConnectTime 20:30:57.710 CAN-QC Thu Dec 5 2013, DisconnectTime 20:31:03.180 CAN-QC Thu Dec 5 2013, CallOrigin        1, ChargedUnits 0, InfoType 2, TransmitPackets 254, TransmitBytes 40640, ReceivePackets 272, ReceiveBytes 43520
Dec  5 2013 20:31:03.184 CAN-QC: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:12/05/2013 20:30:57.572,cgn:5551112222,cdn:41        391,frs:0,fid:36,fcid:E3FF0CD35D4C11E38085CB79F091560D,legID:57,bguid:E3FF0CD35D4C11E38085CB79F091560D
Dec  5 2013 20:31:03.192 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec  5 2013 20:31:03.192 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dec  5 2013 20:31:03.192 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Dec  5 2013 20:31:03.192 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5616
Dec  5 2013 20:31:03.192 CAN-QC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Dec  5 2013 20:31:03.192 CAN-QC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6216
RTR# RTR#
   Result=SUCCESS(0)
   Result=-1
   Result=-1
   Result=-1
   Result=-1
   Result=-1
   Result=-1
   Result=-1
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=-1
   Result=-1
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=-1
   Result=NO_MATCH(-1)
   Result=-1
   Result=-1
   Result=NO_MATCH(-1)
   Result=-1
   Result=-1
   Result=-1
   Result=-1
RTR#
1 REPLY
Can you post the rest of the dial-peer 100 config? If there is none then that is the problem. The dial-peer needs an incoming called number config applied to be matched.
-Bill
(b) http://ucguerrilla.com
(t) @ucguerrilla
Please remember to rate helpful responses and identify helpful or correct answers.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
114
