Sip trunk
silex
A customer would like to investigate using a Sip trunk instead of an ISDN line.
Does the Sip trunk behave just as a ISDN line would in terms of caller i.d etc?
Chris Deren
Yes, you will have to check with the SIP provider for supported features, but all of them should support caller id.
Chris
