Sip trunk
A customer would like to investigate using a Sip trunk instead of an ISDN line.
Does the Sip trunk behave just as a ISDN line would in terms of caller i.d etc?
1 REPLY
Hall of Fame Super Silver
Re: Sip trunk
Yes, you will have to check with the SIP provider for supported features, but all of them should support caller id.
Chris
180
