Sip trunk
I want to know the archetecture used to configure a SIP trunk between CCM and softswitch.
It's CCM --(H323)--> Gateway --(SIP)--> Softswitch
Or CCM --> Softswitch
Re: Sip trunk
You can use:
CCM - h323 or sip trunk - GW(CUBE) - SIP trunk - softswitch
CCM - SIP turnk - softswitch probably not as CCM dosen't support any form of authenication on SIP trunks.
Re: Sip trunk
As per previous answer, use CUBE (an ABC) in between to do the security demarc and protocol conversion.
Config at
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a00808ead0f.shtml
CH
Re: Sip trunk
Thanks for your help
186
