SIP-TRUNKING CONFIG FOR SAUDI ARABIA
Does anyone know the sip trunk config for Saudi Arabia.
we have bought SIP trunk from Local ISTP, can we get  the configuration guide from ISTP.
what information will ISTP provide to us for the configuration of CUBE.
Any help will be highly appriciated.
Hi, Usually the ISP provides
Usually the ISP provides the following:
Domain name
Password
User ID
DID ranges
Number of Sessions
SBC and CPE IP address
It depends on the provider, you'll need to check with them.
Tere.
Please rate helpful posts.
Regards, Tere. If you find this post helpful, please rate! :)
Can you send me the basic
Can you send me the basic configuration steps for configuring sip trunk on cube
you can also check these URLs
you can also check these URLs.
http://www.cisco.com/image/gif/paws/99863/cube-config.pdf
https://supportforums.cisco.com/discussion/11955366/cisco-cube-configuration
//Suresh Please rate all the useful posts.
Dear all
Dear all
I have issues with stc sip line when i try to call from stc mobile  call not response  but when i try to from zain it is working perfectly
Usually called number for calls originated from STC is appended with 011, while calls that originated from other ISP called number comes without 011.
Make sure incoming-called number/ destination number value are set properly on both incoming and outgoing dial-peers. I usually set it as: 0?1?1?44444XX, where 44444XX is an example range.
P.S. you can insert (?) by pressing ctrl+v then release keys and enter (?).
Thank you,
Shadi
Sent from my mobile
make sure you have g711alaw
make sure you have g711alaw under the sip trunk configuration in CUCM
See attachment
Also try with enabling "Media Termination Point Required"
Hello, were you able to
were you able to configure your router, actually i am stuck with router configuration only.
i would appreciate if you can share your configuration file with me.
it would be a great help.
Thanks in Advance.
Hello Mehaomed Are you going
Hello Mehaomed
Are you going to do integration with STC ?. For me i did many integration on KSA with STC all over KSA .
please rate all useful information
Hi Islam, Actually i m new to
Hi Islam,
Actually i m new to it with no prior experience, i would request you to share any running configuration file for cisco 2900 series router. i received configuration from stc:
Thanks in Advance.
Hello sure , i will provide
Hello
sure , i will provide you with a perfect configuration which already tested . I have only on question , did STC share with you any infformation about VLAN id to created?. just a question.
no the above mentioned
no the above mentioned configuration is the only thing i received from STC no vlan ID.
Hi All,I have a similar
Hi All,
I have a similar situation with STC and no proper response from STC to troubleshoot. Was this issue resolved? I managed to get calls bothways but once AA transfers, the calls gets disconnected :(
Sam.
MohamedAs per your DID
Mohamed
As per your DID 133459300-133459499, you have to  use range from 9XXX. because your range of your DID ends with 9XXX. If you use 3XX , you will lose the other range which starts with 4XX.
please explain where do i
please explain where do i have to use this range? in router or in cucm.
Mohamed on CUCM , you will
Mohamed
on CUCM , you will configure the Phones who will need for DID from range 93XX to 94XX. On VG you have to change the translation rule
rule 1 /^.*\(9...\)/  /\1/
dear islam..all my pings are
dear islam..all my pings are working, to the stc gw,  sip server and all. but now outgoing calls. i have 100 DID numbers. Can you provide a working config?
thanks in advance.
Hello Mohamed Kindly check
Hello Mohamed
Kindly check the attached draw which will give you the idea about connectivity between you and STC.
HelloKindly find the below 1
Hello
1-VGW connect to STC
interface  e0/1
no shut
ip address 172.29.55.90 255.255.255.250
duplex auto
speed auto
2-Route to SIP server  in STC
ip route 10.205.20.0 255.255.255.0 172.29.55.89
Note: now try to ping 172.29.55.89 , then ping 10.205.20.50
3-CUBE configuration on VGW
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol cisco
 sip
  bind control source-interface eth0/1
  bind media source-interface eth0/1
4-Outgoing call
dial-peer voice 100 voip
 description ** Outgoing Calls over SIP Trunk >> **
 destination-pattern .T
 voice-class sip dtmf-relay force rtp-nte
 session protocol sipv2
 session target ipv4:10.201.20.50:5060
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
5- incoming DID call
voice translation-rule 1
rule 1 /^.*\(3...\)/ /\1/      / This is example that your internal extensions 3XXX , which match last 4 digits for DIDs/
voice translation-profile DID
translate called 1
dial-peer voice 3000 voip
destination-pattern 3...
sess target ipv4:x.x.x.x   /where x.x.x.x is the IP address for your CUCM/
 translation-profile incoming DID
 incoming called-number .
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
HelloConnectivity trouble
Hello
Connectivity trouble shooting:
1.Be sure that your link is up and your IP “172.29.55.89” is defined in your side.
2.Be sure that you can reach the STC access side by pinging your gateway “172.29.55.89”.
4.Be sure to define the Sip server route toward the gateway by defining the route
“Address 10.205.20.50* Mask 255.255.255.252 Next hub “172.29.27.157”
5.Be sure to reach the SIP server by Pinging the IP “10.205.20.50”
Thanks Islam, i have
Thanks Islam,
i have configured and checked ping is successfull, now what is the next step on cucm furthermore i had an old dial-peer configurations does it make any difference if i leave tham there or do i have to remove tham if so how do i remove tham from my router.
Hi1- For existing Dial-peers
1- For existing Dial-peers , if you are in  production , i suggest do not delete anything.
2- For SIP trunk configuration on CUCM. Go to CUCM- device-Trunk -add new - select SIP trunk - protocol SIP. Just see attached file for SIP trunk configuration
3- Go to CUCM -call routing - route /hunt- route group -add new
name it , then select your SIP trunk which create on step 2.
4- Go to CUCM -call routing - route /hunt-- route list - add new - add RG which created on step 3.
5- Add new Route pattern. Go to CUCM -call routing - route /hunt-- route pattern- Add new
Route pattern:8.XXXXXXXXXX  / I use  8 as i expected that you use 9 or you can use any outgoing code which will be different from your existing /
on Route List assign RL which created on step 4.
on disacrd digits : select predot
6- Test
Thanks a lot for your reply
Thanks a lot for your reply,
actually i created those dial peers while i was testing some code we are not yet live with cisco phones therefore i would like to remove all un-necessary configurations.
i have seen the attached file ip address you mentioned is for sip server and i used my router ip address that was 10.10.5.2
i will change it and follow your instructions.
by the way i need to give different access rights on calls like some employee will have local access only that is 133xxxxxxx.
some others will have mobile access like 05986488xx,
some will have landline facility only like 01122334455, 0123344555 etc.
some will have international calls like +92xxxxxxxxxx.
do i have to create different dial peers for all of the above mentioned access rights or is it a different story.
plz your help is highly appreciated.
Hellowe can configure PTs ,
Hello
we can configure PTs , and CSS to make priority for who can dial calls or not . Just we need to finish test that incoming and outgoing calls is very perfect then we can go for customization . For sure you have to put your SIP IP address 172.29.55.90. I have already updated on attached image.
My incomming call trace . Aug
Aug 12 11:31:56.156: //36966/1975AD308C9D/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x31C7E2D0
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 506812001
Called Number            : 3459300
Source IP Address (Sig  ): 172.29.55.90
Destn SIP Req Addr:Port  : 10.205.20.50:0
Destn SIP Resp Addr:Port : 10.205.20.50:5060
Destination Name         : 10.205.20.50
Aug 12 11:31:56.156: //36966/1975AD308C9D/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g729r8
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 18 (tx), 18 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 172.29.55.90
Source IP Port    (Media): 0
Destn  IP Address (Media): 10.205.20.50
Destn  IP Port    (Media): 54106
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 65
Disconnect Cause (SIP)   : 488
it gives me a dead tone. plz help
Hello 1- Did you test
Hello
1- Did you test incoming and outgoing ?. Kindly add the below:-
sccp local Ethernet0/0
sccp ccm X.X.X.X  identifier 1 priority 1 version 7.0+  /x.x.x.x the Ip address for CUCM/
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/0
 associate ccm 1 priority 1
 associate profile 1 register XCD123456
dspfarm profile 1 transcode
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 maximum sessions 8
 associate application SCCP
no sh
Then add on CUCM- media resources - transcoder - select IOS enhanced -
Then - create MRG-asign the transcoder , after that create MRGL and assign MRG.
Go to SIP trunk- assign MRGL- reset
thanks
Salam Islam,
Salam Islam,
if got the following errors while configuring  plz help.
(dspfarm profile 1 transcode
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 maximum sessions 8
no sh)
Error
Eico-VGR(config)#dspfarm profile 1 transcode
Eico-VGR(config-dspfarm-profile)#codec ?
% Unrecognized command
Eico-VGR(config-dspfarm-profile)#?
  associate    Associations this profile
  codec        The codec rate to be attempted for SCCP controlled connections
  description  Description about this profile
  exit         Exit from DSPFARM Profile configuration mode
  maximum      Configure maximum limit
  no           Negate a command or set its defaults
  rsvp         RSVP support for this profile
  shutdown     Disable or enable this profile
  stun         TRP  STUN support for this profile
I have attached my configuration file for your reference if  i am mastaking plz help.
Hellodo the below, please?
Hello
do the below, please?.
router(config)# voice-card 0
dspfarm
dsp services dspfarm
HelloKindly check the routing
Hello
Kindly check the routing  on your Core switch.
Thanks Islam for the promp
Thanks Islam for the promp reply,
it works, but for the session it only gave me the following
Please configure the maximum sessions for this profile and retry
Eico-VGR(config-dspfarm-profile)#maximum sessions ?
  <1-2>  Number of sessions assigned to this profile
what shoud i select instead of 8 only 1 or 2 is available.
4414
