12-10-2011 03:07 AM - edited 03-16-2019 08:28 AM
Hi everyone!
I'm putting together one 3945 router. I need to know what else do I need for SIP trunking using Cisco Comminication Express Manager? Below is config:
Product | Description |
CISCO3945-V/K9 | Cisco 3945 Voice Bundle, PVDM3-64, UC License PAK |
SL-39-DATA-K9 | Data License for Cisco 3900 Series |
SL-39-SEC-K9 | Security License for Cisco 3900 Series |
FL-CME | Cisco Communications Manager Express License |
FL-CME-SRST-25 | Communication Manager Express or SRST - 25 seat license |
SM-ES3G-16-P | Enhcd EtherSwitch, L2/L3, SM, 16GE, POE |
SL-ES3G-16-IPS | IP Services License Upgrade 16 Port GE ES3 EtherSwitch |
EVM-HD-8FXS/DID | High density voice/fax extension module - 8 FXS/DID |
NM-HD-2V | Two-slot IP Communications Voice/Fax Network Module |
EM-HDA-6FXO | 6-port voice/fax expansion module - FXO |
EM3-HDA-8FXS/DID | 8-port voice/fax expansion module - FXS and DID |
VIC3-2E/M | Two-port Voice Interface Card - E and M |
HWIC-1CE1T1-PRI | 1 port channelized T1/E1 and PRI HWIC |
HWIC-2SHDSL | 2-pair G.SHDSL HWIC |
SM-NM-ADPTR | Network Module Adapter for SM Slot on Cisco 2900, 3900 ISR |
CAB-ACE | AC Power Cord (Europe), C13, CEE 7, 1.5M |
CAB-CONSOLE-USB | Console Cable 6 ft with USB Type A and mini-B |
S39UK9-15104M | Cisco 3925-3945 IOS UNIVERSAL |
PWR-3900-AC | Cisco 3925/3945 AC Power Supply |
3900-FANASSY | Cisco 3925/3945 Fan Assembly (Bezel included) |
C3900-SPE150/K9 | Cisco Services Performance Engine 150 for Cisco 3945 ISR |
ISR-CCP-EXP | Cisco Config Pro Express on Router Flash |
MEM-3900-1GB-DEF | 1GB DRAM (512MB+512MB) for Cisco 3925/3945 ISR (Default) |
MEM-CF-256MB | 256MB Compact Flash for Cisco 1900, 2900, 3900 ISR |
PVDM3-64 | 64-channel high-density voice and video DSP module |
SL-39-IPB-K9 | IP Base License for Cisco 3925/3945 |
SL-39-UC-K9 | Unified Communication License for Cisco 3900 Series |
Aleksei
12-10-2011 11:41 AM
There's no license for SIP trunking, as long as you have CME you can do SIP trunks
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-11-2011 11:26 PM
Aleksei
