Silver
SIP trunks in route group
We have a configuration where we have two SIP trunks in a route group, and these trunks connect to an IVR
When the first IVR is down, automatically the second trunk is used (CM send invites no reply)
Question:
When all channels on the first IVR are used we receive a busy signal and the second IVR is not used.
Is this correct? Can we change something so that when we receive a busy on the first SIP trunk, the second is used?
Jan
Everyone's tags (4)
1 ACCEPTED SOLUTION
Blue
HI
Make service parameter  Stop Routing on User Busy Flag: Required Field  as False.
Ronak Patel
rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
HI
Ronak Patel
rate helpful posts.
Silver
Re: SIP trunks in route group
Hello Ronak,
Thank you for your answer, works perfectly!
Bye,
Jan
617
