sip-ua does not come back after Internet loss
My CME 8.6 works great.  But, when I lose my Internet connection inbound calls do not work until I delete the sip-ua and re-create it.  Outbound calls work as soon as the Internet is back up.  Is there anything I can configure so that inbound calls work after Interent loss automatically?
My Interent IP is dynamic. The Internet source is on another router/switch on the 192.168.30.0 netowrk.  The IP phones are on the 10.110.0.0/24 network. My SIP provider is simonics.com which connects to Google Voice.  Hey, its a free phone line!
voice service voip
ip address trusted list
  ipv4 72.9.149.69
  ipv4 216.155.131.52
allow-connections sip to sip
redirect ip2ip
sip
  registrar server
voice translation-rule 1
rule 1 /3865559001/ /1000/
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/1.110
encapsulation dot1Q 110
ip address 10.110.0.1 255.255.255.0
ip helper-address 172.16.2.2
ip pim dense-mode
ip nat inside
ip nat inside source list NAT_ACL interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.30.2
ip route 72.9.149.69 255.255.255.255 192.168.30.4
ip route 216.155.131.52 255.255.255.255 192.168.30.4
dial-peer voice 100 voip
description *** Incoming Calls VoIP ***
translation-profile incoming Incoming_calls
preference 1
session protocol sipv2
session target sip-server
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer inbound selection sip-trunk
sip-ua
credentials number 3865559001 username GV13865559001 password abc123 realm GVGW
credentials number 9045551577 username GV19045551577 password abc123 realm GVGW
authentication username GV13862439001 password abc123
registrar dns:gvgw7.simonics.com:5070 expires 300 tcp
sip-server dns:gvgw7.simonics.com:5070
1 ACCEPTED SOLUTION
Re: sip-ua does not come back after Internet loss
Hi try to add refresh-ratio 50 to your registrar configuration.
eg.
registrar dns:gvgw7.simonics.com:5070 expires 300 tcp refresh-ratio 50
Carlo
Please rate all helpful posts "The more you help the more you learn"
eg.
Carlo
AWESOME!  AWESOME! AWESOME!
That worked!!!!  Thank you so much!!!!
204
