Community Member
SIP vs SCCP
I am installing Cisco Unity and for one of the steps its asking whether on Call Manager I am using SIP vs SCCP - How would I find that out?
Thanks!
VIP Purple
Re: SIP vs SCCP
SIP is used only when the integration uses only SIP endpoints. If you're integrating with a version of CCM prior to 5.x, you will be using SCCP for the integration.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cusiptrunkmtx.html
Hope this helps. If so, please rate the post.
Brandon
Community Member
Re: SIP vs SCCP
Thanks Brandon!!
684
