Community Member
SIPconnect compliance and CUBE ISR2
Hello
I am looking for a official document in Cisco, saying that the CUBE for ISR2 3925 are certified SIP Connect Compliance by SIP Forum. I found it for the ASR 1000 but not for the ISR2.
Somebody can help me to find the way to confirm that the ISR2 do comply with this certification.
Thanks in advanced.
Alexis
Silver
Re: SIPconnect compliance and CUBE ISR2
Community Member
Hi Alexis,
Are you looking for anything in particular or want to check whether we are compliant on a particular RFC.. You can let me know and we can confirm with you.But for most part, we are compliant. Also the document that Abu provided will be very helpful.
Pashmeen Mistry
538
