sizing/Call Manager/CME
Hello
am looking for usefull documents that helps me to do a propere sizing for call manager,CME,CAN Y HELP in this topic
  • IP Telephony
Re: sizing/Call Manager/CME
The best place to get this information is the SRND:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/uc7_0.html
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hi William Bell
Thanks, also can i define the customer requirment from this Docs
No, the customer requirements should come from the customer.  You can use the SRND to educate yourself on the interoperability considerations, application requirements, scalability factors, etc.   Having that knowledge will help you guide the customer to a solution that meets their requirements but it won't define the requirements for you or them.
If you are looking for tools to help you with the discovery phase of the project (where technical and business requirements are defined) then you may want to access the Steps to Success partner portal on CCO.  If you are a Cisco partner you should have access to this portal from the partner pages.
HTH.
Bill
Plz post me the link in order to acess it
SRND: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/uc7_0.html
Steps to Success: http://www.cisco.com/go/stepstosuccess
HTH.
Bill
Silver
For sizing up CME sites, use this URL:
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd804e773d_ps5853_Products_Data_Sheet.html
Will tell you how many users are supported per ISR Router i.e  the Cisco 3845-CCME bundle supports 240 users.
CISCO3845-CCME/K9
Cisco 3845 Voice Bundle with IOS SP Services, PVDM2-64, FL-CCME (240 users), 128 MB Flash/512 MB DRAM
For Callmanager:
Maximum Number of Devices per Server Platform
Cisco MCS 7845 (All supported models)
7500
Cisco MCS 7835 (All supported models)
2500
Cisco MCS 7825 (All supported models)
1000
Cisco MCS 7815 or MCS 7816 (All supported models)
300
From this section of the 6.x SRND;
Unified CM Platform Capacity Planning
966
