Skype Integration with CME
Hey Guys
I need your help but first
is it possible to integrate skype with CME
if yes
HOW
Thanks in advance
1 REPLY
Re: Skype Integration with CME
Hi.
You need a third party software such as skystone which allows you connect cme to skype through a sip trunk.
Carlo
Please rate all helpful posts "The more you help the more you learn"
189
