07-23-2008 12:15 PM - edited 03-15-2019 12:10 PM
How can I check my timing on the gateway or set it? Provider says the line looks good but the slips keep comming through.
07-23-2008 12:32 PM
Michael,
You can do a "show controller t1" on the router and see if you are getting slip errors. If so, issue the following command:
network-clock-participate wic X
network-clock-select 1 t1 X/X/X
I hope this helps.
kb
07-23-2008 01:01 PM
I will give this a try thank you. I am assuming the X stands for interface and port numbers?
07-23-2008 01:05 PM
Yes...
07-23-2008 01:16 PM
Michael,
Use the following command to check the source of your clocks..
show network-clocks
