Slow Outgoing faxes
We recently switched out our Avaya PBX for Call Manager and are having issues with sending faxes and how slow they go out. Incoming faxes come in at regular speeds, but sending faxes takes forever. The voice gateway is a 3825 configured as H323 and we connect the fax machines to a vg224 using SCCP. Any suggestions would be greatly appreciated. Thanks.
Here is what the dial peers look like
dial-peer voice 1 pots
description INCOMING CALLS (DID's)
translation-profile incoming Add3
incoming called-number .
direct-inward-dial
port 0/0/0:23
dial-peer voice 2 pots
translation-profile incoming OPERATOR
incoming called-number **********
direct-inward-dial
port 0/0/1:23
dial-peer voice 102 voip
description CCM01
preference 2
destination-pattern 46...
progress_ind setup enable 3
progress_ind progress enable 8
voice-class codec 1
session target ipv4:10.X.X.X
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate disable
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 101 voip
description CCM02
preference 1
voice-class codec 1
session target ipv4:10.X.X.Y
fax rate disable
no vad
dial-peer voice 911 pots
trunkgroup LOCAL
description 911
destination-pattern 911
forward-digits all
dial-peer voice 9911 pots
trunkgroup LOCAL
description 911
destination-pattern 9911
forward-digits 3
dial-peer voice 411 pots
trunkgroup LOCAL
description 411
destination-pattern 411
forward-digits all
dial-peer voice 9411 pots
trunkgroup LOCAL
description 411
destination-pattern 9411
forward-digits 3
dial-peer voice 311 pots
trunkgroup LOCAL
description 311
destination-pattern 311
forward-digits all
dial-peer voice 9311 pots
trunkgroup LOCAL
description 311
destination-pattern 9311
forward-digits 3
dial-peer voice 5 pots
trunkgroup LONGDISTANCE 1
trunkgroup LOCAL 2
description 5 digit dialing over PSTN
translation-profile outgoing SRST
destination-pattern 4....
dial-peer voice 7 pots
trunkgroup LOCAL 2
description 5 digit dialing over PSTN To REMOTE
destination-pattern 7....
dial-peer voice 97 pots
trunkgroup LOCAL 1
trunkgroup LONGDISTANCE 2
description 7 DIGIT LOCAL DIALING
destination-pattern 9[2-9]......
dial-peer voice 910 pots
trunkgroup LOCAL 1
description LONG DISTANCE DIALING
destination-pattern 91[2-9].........
dial-peer voice 9011 pots
trunkgroup LOCAL 2
description INTERNATIONAL DIALING
destination-pattern 9011T
prefix 011
165
