SMALL GATEWAY WITH BRIS
I'm looking for a small gateway with 1,2 or 4 BRI voice interfaces. Cisco 2901 is really big for this neccesity. Could you help me find anything smaller?
Blue
HI
See if UC500 helps.
http://www.cisco.com/en/US/products/ps7293/index.html
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hall of Fame Super Gold
Re: SMALL GATEWAY WITH BRIS
Cisco doesn't make these with the expection of C887VA-V-K9 and similar. however these are full-featured routers not gateways.
.You will have to use third-party.
We use the 1861 ISRs both with the BRI and FXO options for SRST purposes at remote sites, and they are used as the local gateway for emergency calls, when registered with UCM.
They are reasonably cheap and flexible, plus they have the bonus of the 4x FXS and 8x PoE Ports as well. Perfect for small outlying sites.
Cheers,
Alistair
We use Innovaphone IP305 (2 BRI) and IP800 (4 BRI) media gateway. These devices support SIP and H.323 and are compliant with Cisco. You can find more info on the vendor web site.
Regards.
240
