Small VOIP config with 2 x 7940
I am really a newbie in the CISCO world , and even more in telephony.
I just purchased one CISCO 7940 (Ver:8.0(5.0)) on eBay and wait for a other one to arive.
It was not dificult to configure the VLAN 10 and OPTION 150 and the RINGTONES.
My phone receive the files without errors.
But I was wondering how I can asign a phone number to my phones ?
At the moment I have no dial tone , do I need to add some extra HW , I have only :
CISCO 2691 :  System image file is "flash:c2691-adventerprisek9-mz.124-25c.bin"
and a switch CATALYST 3550
What kind of card do I need to add to be able to access a external analogue line (PABX)
Are their some SIP servers for free for test ?
Thank You in avance for your help and of-course you will be rated
PS:
1.If you have some link to a more or less same config you are welcome , it is not urgent , I just prepare myself for my CCNA training in October.
What else can you do when it is raining cats and dogs during your holiday's
2. Where can I download a virtual cisco IP phone ? on some youtube I see a virtual phone.
3. In the system:/its/ folder I can see a lot of of countries , I was wondering if this is only a language issue or maybe also a system issue ?
Best Regards,
Didier
Router#sh run
Building configuration...
Current configuration : 3026 bytes
version 12.4
hostname Router
boot-start-marker
boot system flash c2691-adventerprisek9-mz.124-25c.bin
boot-end-marker
enable secret 5 $1$9E60$NHlYQ8E8OAzS3O7H5k1i3.
enable password cisco
no aaa new-model
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1 172.16.1.9
ip dhcp excluded-address 172.16.2.1 172.16.2.9
ip dhcp pool DATA_SCOPE
   network 172.16.2.0 255.255.255.0
   default-router 172.16.2.1
ip dhcp pool VOICE_SCOPE
   network 172.16.1.0 255.255.255.0
   default-router 172.16.1.1
   option 150 ip 172.16.1.1
   dns-server 8.8.8.8
no ip domain lookup
ip domain name DRI.BE
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username cisco privilege 15 secret 5 $1$mZkJ$4yOxPOD1Qzr2rNegO9Nv30
interface FastEthernet0/0
no ip address
no ip route-cache
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 172.16.1.1 255.255.255.0
no ip route-cache
interface FastEthernet0/0.50
encapsulation dot1Q 50
ip address 172.16.2.1 255.255.255.0
no ip route-cache
interface Serial0/0
no ip address
no ip route-cache
shutdown
no fair-queue
interface FastEthernet0/1
no ip route-cache
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
no ip route-cache
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
no ip route-cache
shutdown
interface Serial1/2
no ip address
no ip route-cache
shutdown
interface Serial1/3
no ip address
no ip route-cache
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
snmp-server community public RO
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
control-plane
telephony-service
load 7960-7940 P00308000500
max-ephones 5
max-dn 5
ip source-address 172.16.1.1 port 2000
time-format 24
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 4 gain -6
directory entry 1 555123 name Didier
directory entry 2 1234567890 name Veronique
line con 0
speed 115200
line aux 0
line vty 0 4
password cisco
login
end
Everyone's tags (6)
2 ACCEPTED SOLUTIONS
Green
Didier,
Try this something like this to make basic calls between the
phones
ephone-dn 1 dual-line
number 2001
ephone-dn 2 dual-line
number 2002
ephone 1
mac-address 1111.1111.1111
type 7940
button 1:1
ephone 2
mac-address 2222.2222.2222
type 7940
button 1:2
For analogue access you need an FXO type card and some DSP chip resource
Here is the link to Call Manager express Admin guide
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeover.html
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
If you want to try a softphone and you have a valid contract and access to CCO SW you can try IP Communicator, otherwise, just google ip blue softphone and you can try that one out.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Green
Didier,
phones
number 2001
number 2002
ephone 1
type 7940
button 1:1
ephone 2
type 7940
button 1:2
Alex.
java
java
Thank you for your great help.
Best regards,
Didier
475
