Community Member
SNMP E1/PRI
Hello!
We have Cisco 2851 with two VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
card type e1 0 0
card type e1 0 2
I want monitoring active calls, but can see only for card 0/0:
# snmpwalk -c public -v 2c ROUTER 1.3.6.1.4.1.9.10.19.1.1.9
SNMPv2-SMI::enterprises.9.10.19.1.1.9.1.3.0.0 = Gauge32: 2
SNMPv2-SMI::enterprises.9.10.19.1.1.9.1.3.0.1 = Gauge32: 0
What can i do to start monitoring my card 0/2?
Community Member
Re: SNMP E1/PRI
Anybody.. up
Re: SNMP E1/PRI
Re: SNMP E1/PRI
Scratch that. I just realized the ISR series routers do not support the CISCO-POP-MGMT-MIB.
Researching still...
Michael.
Re: SNMP E1/PRI
So the issue of ISR routers not supporting CISCO-POP-MANGAGEMENT MIB is documented in CSCee16176. You may want to use the CISCO-ISDN-MIB instead.
Michael.
637
