Community Member
SNMP monitoring no working in CUCM 6.1.3
When I put in the command snmpset to adjust the log level, it goes wrong.
Here the output of the command:
D:\usr\OV\bin>snmpset -c OURSTRING -v 2c 10.250.42.10 1.3.6.1.4.1.9.9.41.1.1.2.0 integer 1
snmpset: No response arrived before timeout.
snmpset: Possible causes include invalid community name, agent is not running, or the node is unaccessible.
BUT:
community string is valid, agent is running and the node is accessible.
Do I overlook something?
1 REPLY
Bronze
Re: SNMP monitoring no working in CUCM 6.1.3
Check if SNMP is enabled on the device. Verify the read community string. Make sure there is no access list or firewall between ANI and the device that blocks SNMP traffic.
332
