SNMP OID for PRI Utilization
jmbrady
Ok, All I'm trying to do is find an SNMP OID that tells me how many B-channels are in use on the PRI. I've tried lots of OID's, even ones that are described as doing just want I want them to, but they either come back with a HUGE number or zero.
Anyone have any experience with this and can help me out?
bcorbet2004
Did you ever find an OID that can give you back how many channels are in use.  I was trying to use the POP-MGMT-MIB, but it does not appear to be fully supported on the 3845 with more than 2 PRIs.
BC
