SNMP OID for PRI Utilization
Ok, All I'm trying to do is find an SNMP OID that tells me how many B-channels are in use on the PRI. I've tried lots of OID's, even ones that are described as doing just want I want them to, but they either come back with a HUGE number or zero.
Anyone have any experience with this and can help me out?
1 REPLY
Re: SNMP OID for PRI Utilization
Did you ever find an OID that can give you back how many channels are in use.  I was trying to use the POP-MGMT-MIB, but it does not appear to be fully supported on the 3845 with more than 2 PRIs.
BC
339
