Community Member
SNMP polling ISDN channel status - All come back IDLE
I've just added a Custom MIB for monitoring the status of the Primary Rate ISDN interface. I want to monitor the usage of the channels to get an idea of how busy we get. I get the data back but unfortunately they all come back as IDLE. I even made a call and refreshed but still all channels show IDLE.
Is there anything obvious I may have missed out on the router configuration?
The MIB I am using is 'isdnBearerOperStatus' [.1.3.6.1.2.1.10.20.1.2.1.1.2]
Thanks!
Craig
Hall of Fame Super Gold
Re: SNMP polling ISDN channel status - All come back IDLE
That should work. Are you polling appending channel number to the oid ?
Community Member
Solarwinds cleverly creates a table based on all the channels it finds and puts the status alongside each. To double check it wasn't a problem with Solarwinds I used GetIf to view the OID values and all channels come back Idle. Are there any specific commands required on the Router interfaces? Are there any SNMP commands that need enabling?
Not that I'm aware. Possibly a bug, ISDN code is one of the buggiest parts in IOS.
Community Member
Hmm I think I might raise a TAC to have this looked into...
Try upgrading IOS first.
Although it would be important to have the bug investigated, more important is that your application works.
Then other bugs will come up to keep TAC busy anyway.
Community Member
I have checked the latest Router we installed last December and this has the problem aswell. It's IOS is quite recent - Version 12.4(9)T7
You're then in the right position to ask cisco for a fix. Don't be put down if that requires much time and insistence.
Community Member
I have monitored the active channels on a MGCP controlled gateway to get usage stats on PRI interfaces.
Using the CISCO-POP-MGMT-MIB, you can monitor the variable with OID 1.3.6.1.4.1.9.10.19.1.1.4
This will show the number of active DSO channels on the PRI interface.
Community Member
Hi Colin,
I want to get the MGCP controlled PRI B channel status on ISR G1 and G2 routers. On what models of routers did you successfully use the "CISCO-POP-MGMT-MIB"?
Kapil
Community Member
Hi Kapil
I got this working on cisco 2800, 37xx and 39xx series routers.
Colin
On 31 January 2012 18:09, kapilatrish <
886
