03-02-2009 04:51 AM - edited 03-15-2019 04:33 PM
I'm trying to demo SNR.
I think I've done all the needed config, but selecting into the Device page the Owner User ID, because the field is grey and I can't select any user.
When I try to send the call to my Remote Destination device by pressing the Mobility key, I get the following error:
MobileConnect Off
You are not a valid Mobile Phone User
Does anyone know what I must be doing wrong?
Thanks in advance.
Best regards,
Carmen
Solved! Go to Solution.
03-02-2009 05:37 AM
Hi Carmen!
With EM owner user id is grayed out. Please check if you are using Extensio Mobility. if that's the case, uncheck EM, assign a owner user id and reselect EM.
Once you do login via Extension Mobility on a phone the owner user id would change to reflect the user id of the logged in user.
Hope this helps!
Teresa.
03-02-2009 05:37 AM
Hi Carmen!
Hope this helps!
Teresa.
03-02-2009 01:40 PM
Hi Teresa!
Many thanks for your help. You were absolutely right
Best regards,
Carmen
