08-27-2012 09:37 PM - edited 03-16-2019 12:54 PM
Trying to get the following working:
ephone-dn 120 dual-line
number 1120
label Matt 1120
description Matt
name Matt
mobility
snr 81XXXXXX1952 delay 0 timeout 10 cfwd-noan 1198
snr ring-stop
call-forward noan 1198 timeout 3
call-forward busy 1198 primary
no huntstop
night-service bell
Debugs only yield inbound call leg, but nothing forwarding from CME. Running this extension on CIPC. Inbound call rings and rings on CIPC, but never forwards out to the cell phone or to voicemail (1198). If I unregister the CIPC, the calls forward right to voicemail. If I CFwdAll to the same SNR number, calls forward as expected when calling into the DN. The button I included on the template turns mobility on and off as expected. When mobility/MobileConnect is disabled, calls come in and forward to voicemail after 3 seconds.
Unfortunately with no debugs, the SNR functionality is just dead in the water.
Is there a global command that needs to be issued or does the router need to be reloaded after issuing the command for the first time?
Solved! Go to Solution.
08-28-2012 02:16 AM
Have a look here at this thread and see if you find any useful information. I will also suggest you remove the night-service bell command and test again..
https://supportforums.cisco.com/thread/2145657
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
08-28-2012 02:16 AM
08-28-2012 08:07 AM
Thanks, nightbell was part of the issue and the other part was the need to update to 9.0.
