Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Soft Keys Not Working
I am implementing a Cisco Call Manager 4.1 using Cisco IP phone 7960. Some of the soft keys appear not to be working. The on hold key will not work at all, nor does the xfer. Also when a second call comes into the phone the answer key does not work. If the first call is cleared down while the second call is ring on the phone, then the answer key works.
Any ideas ?
1 REPLY
Green
Re: Soft Keys Not Working
I assume this is not working for PSTN calls please confirm...
If using H323 GWs for incoming calls...please try unchecking MTP required checkbox in H323 GW config...
Check region between GW and MTP...
If using SW MTP...check G711 is configured between GW-MTP-IP Phone...
Does it work for internal IP to IP Phone calls?
124
